3.1…a pair of NHT Classic Threes…one Von Schweikert VR-1…and an Orb Audio Super 8 subwoofer.
What Speakers Do You Own?
- Thread starter DeusEx
Rich77
- Sep 26, 2010
Yamaha 5.1 Sp-1800s hooked up to my room
LFF
Co-Organizer for Can Jam '09
Member of the Trade: Paradox
- Dec 6, 2004
JBL 4311 (5 of them for home theater and 4 for my main stereo set-up)
Akai SW-170 Studio Monitors. That's a 15 inch woofer! Some of the best sounding speakers I have heard. These are my other stereo set-up. I use these to double check important material.
Mackie HR-824 Active Near Field Monitors. These are my workhorses.
11amaberry
- Feb 28, 2010
Nice stuf LFF! I'd like to hear some good moniters someday
LFF
- Dec 6, 2004
Nice stuf LFF! I'd like to hear some good moniters someday" width="" />" class="bbcode_smiley" height="" src="http://files.head-fi.org/images/smilies//smily_headphones1.gif" title="" class="bbcode_smiley" height="" src="http://files.head-fi.org/images/smilies//smily_headphones1.gif" title="" width="" />" width="" />
Thanks! Try to look for some used JBL 4311's. You can sometimes snag a pair for well under $300! A real steal IMHO considering the sound quality and spl these things can put out. What I love about them is that they really rock out at loud volumes but are equally as good at low volumes without losing the details and impact - something which is hard for many speakers to do.
Meliboeus
- Apr 17, 2008
It's an old photo still work in progress, now at least i've a proper table for the electronics.
Speakers are DIY made of 25mm thick MDF, weighting 50kg each, the woofer is loaded in a transmission line, i've done all the woodworking and soldering, the project used is not mine.
They're a classic two way design with passive crossover, drivers are from Ciare, which is a popular italian manufacturer;
Both 1.2" silk dome tweeter and 10" bicone extended range have 150W continuous power handling and high sensitivity, as they are intended for PA application,that means high spl are easy even with my modest 45W entry level Denon amp. I use my laptop as source and have implemented a room correction convolution filter which to my experience is extremely effective in controlling nasty room resonances and linearizing frequency response;
It's nothing really expensive but at least have the raw membrane area and power to handle any genre well, try blasting some Neurosis on these and you will be happy
LFF
- Dec 6, 2004
It's nothing really expensive but at least have the raw membrane area and power to handle any genre well, try blasting some Neurosis on these and you will be happy" class="bbcode_smiley" height="" src="http://files.head-fi.org/images/smilies//biggrin.gif" title="" width="" />
Nice! Would love to give those a listen and run through with my demo CD. I'm a big fan of passive crossovers and transmission line designs. How much did the total project cost (if you don't mind saying)?
Meliboeus
- Apr 17, 2008
Very little, around 120€ in wood and materials, less than 200€ for the drivers and around 80€ for decent crossover components.
LFF
- Dec 6, 2004
That is a good bargain!
Very nice work BTW. Wish I could be that handy.
- Feb 23, 2008
Very cool setups in here
Ive just got two paradigm monitor 7's v5 that have been relegated to surround duty, along with some Emotiva ERM-1's that i use as my mains, and a Epik Sentinel Subwoofer(in less that 1000 cubic feet, its a bit overkill
) all powered by a 13 year old yamaha DSP-A1 reciever, which is a beast of an amp, back when recievers actually weighed something...i got lucky and got it as a hand me down from my dad
C4rl
- Dec 16, 2009
[size=10pt]PMC OB1’s in my main system, Wharfedale[/size] Diamond 10’s in my bedroom.
KevDo
- Aug 1, 2007
Just one set, just a pair of Quad 22L's. I love them but I do have the urge to try some electrostatics but since i'm a big skint scaredy cat the urge is nothing but.
lilkoolaidman
- Mar 26, 2009
elbuzzard
- Mar 12, 2008
Pain of mind/Word as law/souls at zero......thats as far as I go.
