bigshot
You will need some sort of headphone amp for IEMs and HD800s for the output from the iPhone. The impedance is pretty sure to be a mismatch. Do you have a headphone amp you can use?
I was intending to use the Mojo alone with the iems as that is how I listen. I have an O2. HD600's not 800's BTW.You will need some sort of headphone amp for IEMs and HD800s for the output from the iPhone. The impedance is pretty sure to be a mismatch. Do you have a headphone amp you can use?
Out of curiosity, what is/are the audible effect/ of an impedance mismatch? I've probably heard them before but ever really paid attention enough to diagnose as such.
The Mojo doesn't actually have an amp section. It takes the output directly from the DAC. I should amp both the Ciem's and the 600's from the iPhone?The mojo would be fine. It has an amp built in, right? The direct output from the iPhone would require amping.
as regards Bigshots test; I was convinced I could hear a difference between the audio formats, I did spend a good 45 - 50 minutes on it. Then I realised that his test was flawed because the audio samples where themselves contained within an audio sample (Flac), instead of being separate files.
That isn't true at all and you know it. You turned in your results and they were randomly distributed because you misunderstood the instructions. When you change your story now to try to make your failure my fault, it tips your hand. A lossy file contained in a lossless file sounds exactly like the original lossy file. I put it in the lossless file so you couldn't peep at the data rate by doing a get info on the file. This makes it impossible to rank all the files without actually listening to them and discerning the quality by ear. You intended to cheat the test and you found out you couldn't. Now you're trying to blame it on me.
You spend 40 minutes on the test? The test file itself has a longer running time than that. You're admitting you didn't even listen to the whole file. Ha ha.
NEXT!!
Yes. That's the Mojo. This is Relic's post which mentions the output of Mojo.Is this what you have? If so, this is a DAC and amp in one.
https://www.audiolab.com/chord-mojo...z4V5WaAp3U4YjT0LFhTeZG4oJw8nJN9QaAvlJEALw_wcB
You would need an amp for the iPhone too to compare apples to apples so to speak.
Here is some great information about impedance with regards to headphones and amps. (the link may not stay for long if this site still has it in for this blogger)
https://preview.tinyurl.com/bp7crrr
Volume level, frequency response imbalance and degraded dynamics. I know what you're talking about though... No one seems to give straight answers on this subject. They get sidetracked into details and forget to state the obvious clearly enough.
