Shike
- Feb 1, 2005
Your wording isn't exactly clear here, please clarify.
Portable amps usually don't have the same specs, like loads they're able to support without clipping.
Those aren't entire specs which Headroom don't advertise. Still, I'm happy with $200 amps like the X-Head that measure extremely well.
My point is aimed at distortion and the trasnformers impact.
Yes you have, you've been endorsing anti-negative feedback designs.
Plenty of companies that make high-end gear would say Stereoplay is full of it. Furthermore, I would consider damping factor a matter of classical measurement data since if I remember right it's been around since the 60's. It's established and well documented.
Fool me one shame on you, fool me twice shame on me . . . you've either been confusing them a lot or making lots of typos.
I was just explaining why digital chips can sound like certain tube designs.
Wait, how did I say I was a liar?
I believe you're more mistaken than anything else . . . it's certain questionable companies I'd call dishonest or liars.
Examples? Also define recovered.
We can't tell if the effect is consistent because many refuse partaking in a cited DBT.
EDIT:
Either way I'm stepping out of this argument. It's just going to do another circle again.
Originally Posted by JaZZ /img/forum/go_quote.gif You may have noticed the part about «Stereoplay»'s research. They have found out how minimal harmonic distortion defines the resulting characteristic. It's not that amps really measure the same, let alone when measured with a complex dynamic load. |
What does portable or desktop design have to do with measuring data? I think you believe in identical sound with identical measurements. The wire with gain scenario. |
(Portable) Micro Amp: THD at 1 V output: <0.002, frequency response: 10–50k, ±0.3 dB (Portable) Desktop Amp: THD at 1 V output: <0.002, frequency response: 10–50k, ±0.3 dB Ultra Desktop Amp: THD at 1 V output: <0.002, frequency response: 10–50k, ±0.3 dB So why should you spend more than $349! |
Euphonic distortion is the main argument against tubes. I thought you were addressing that when speaking of the inherent inaccuracy of tube amps. I don't consider output transformers a decisive weakness. So if that's your only argument... From your point of view you should look at the signal accuracy, not the design. Anyway, one point I agree with you is that tube amps aren't ideal for driving woofers. |
It's a disadvantage. I never said the opposite. I wouldn't recommend OTL designs with speakers. With high-impedance headphones they usually harmonize well. |
As mentioned, I have never measured amps myself, but the «Stereoplay» measurements speak a clear language: Negative feedback is evil. Maybe in moderation it is tolerable. But that's not exactly the point. The point is that amps do sound different beyond the classic measurement data. |
You're right (not with your assumption about my knowledge, though) – it was just a typo. I meant excessively high oputput impedance. |
Again: I don't listen at the upper end of amps' power capacity, so their clipping characteristic is relatively uninteresting. |
So are you saying that you are a liar |
because so many things I've stated are definitely wrong in your book (which you have let me know clearly)? |
No, that's not true (and note that I don't call you a liar). I have fallen for the placebo effect many times, but have recovered very well. |
[/i]I don't recall such a statement from a cable-sound proponent – most admit to have experienced placebo effects. It's more like: If a sonic effect is consistent and reliable, it's not placebo. |
EDIT:
