rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
I am still trying to figure out where this "200khz" comes from.
Original Linkwitz : 700hz
Chu Moy Variant : 700hz
Simpson Variant : 700hz
Meier Natural :660
Meire Natural bass: 700hz
John Conover : 684hz
So they all have the hinge at the midband and effect from that point downwards set by a capacitor.If too high in the range there would be a high frequncy blend that would blow the left/right imaging and effectively be a monoing device.Because the 3db point is set to these ranges there will obviosly be some effect in higher ranges but this diminishes at the standard for a single pole filter which is -6dB per octave meaning it will slope graudually (as intended) rather than be a rapid cutoff or dead stop band.
The low bass is most often already a mono signal,usually below 100hz or so, meaningless in this or any other context of blending because it is already a mono signal.
Strictly speaking no.All are totally passive devices using resistors/capacitor filters except for the Headroom and original J.Conover but even he offers a totally passive desin option (direct Headphone Drive).The Jan Meier active circuits are for the actual headphone amp and he chooses to buffer the input of the crossfeed to present it with a low impedance and a known impedance so the network response can be predicted but this is not essential unless the driving source has a high impedance such as some tube stages.The output if connected to a headphone amp will see the input impedance of the headphone amp as if a buffered output and since this is pretty much standardized at 100K ohms the network response can be predicted.changes in either input or output impedance (network driving source and output load ) will cause slight changes in network response but not extreme enough to ruin the effect.
The Meier Audio Corda Cross addresses the possible impedance mismatches by adding in passive bass and treble trim controls so the effect can be actually tailored to individual taste.I will not comment on the Headroom matrix because even though I know how it works it is their design and if they wanted the actual design details out would have posted them on their web page.
The only downside to most crossfeed devices is there is some negative gain (oxymoron
),some level attentuation as any passive network will have.The other problem is not all are totally out of circuit when bypassed and effectively are "blend" controls even when in the bypass position.Both are easily fixed by upping the volume control on the amp for the attenuation and installing a proper defeat switch for the blending.Other than that it comes down to personal choice and preference but the fact that recordings mixed for speaker playback are different than those recorded for headphone playback (rare !) is not in doubt.
I do find it interesting and something I have observed over time is usually the most vocally opposed to a headphone crossfeed network mostly never even listened to one and if they did only for a very brief time.Those that have extensive time with one and still question the validity usually complain not that it destroys the sound but that the effect is so unobtrusive as to be hard to detect-as it should be-so what is the point of having it ?
Detail is not effected,just the direction it comes from unless crappy parts are used
But he does still have step-by-step build instructions on his web page including a proper bypass position on the "tweak" page (suggested by me
).Total build time is about 15 minutes.build cost about ten bucks american so an easier/cheaper "toy" for experimenting would be hard to find.Probably would make sense before laying out cash for a commercial device to whip one up and see if YOU like the effect or not.
****Edit****
even those who do not know which end of the soldering iron is the hot end can usually find some local pimply faced technical high school attendee who will be more than happy to whip one up.If that is not an option maybe some old beezer family member with a HAM Radio liscense.They ALL know electronics as it is required to pass the test for a liscence.
Meier Natural :660
As with the natural crossfeed filter, the direct signal with the Linkwitz filter shows a signal loss at lower frequencies, (-1.0 dB at 60 Ohms, -0.35 dB at 50k Ohms). However, more important is that a mono-signal at frequencies below 700 Hz is increased by up to 1.3 dB at a 60-Ohm load and up to 1.9 dB (!) at 50k Ohms. The delay times for the Linkwitz design (figure 2) are fairly natural, as the crossfeed signal has similar filter frequencies and thereby should have similar delay times as the natural crossover filter. |
Add to the problem of crossfeed is that it adds electronics in the signal path, just as equalization does, and this has to degrade the signal, however slightly |
No doubt the bigger and more filled-in soundstage is often desirable when inner detail is not important to the listener. There is no free lunch - either crossfeed or no crossfeed has its good points and it bad. |
He doesn't sell that anymore... |
****Edit****
