Ah ha! I caught you! You didn't mention: C) Meant to simulate a perfect listening environment when the audio is reproduced on 2/5 speakers |
Ooops ! What I
meant to say was...um.....er...OK.I take the hit
I think that if you're going to synthesize a room, synthesize a really good sounding one---not some stark set of walls. |
Exactly.Remeber the old Yamaha Ambience Syntesizers ? Pretty good implementation of the "venue" even though the technology at the time had severe limits.
Instead of some "room" you had a choice of presets for specific (sometimes very specific down to hall name !) arenas and you would suit the music to the "this is possible" room size PLUS had the ability to even firther "tweak" to your favorite position in the audience.
So Rock would be anything from "Bar" to "small arena" or "large" arena and with the grand daddy of "outdoor stadium" (which was also dead on for Marching Band music)
Then you had "jazz club" for small groups,"Cathedral" for pipe organ music plus sevaral concert halls for classical.
One thing about the devcie that was a total turn off for me even though i admired the effort was the fact that
everything had to go through this device before it reached the power amp so whatever its circuitry colorations/limitations so would everything going through be effected.not good if you have a transparent or personally satisfying "sound" that is then sent to a bazillion transistors and hundreds of capacitors
The core idea though was music is not a static medium and you need to fit the "room" to a venue that could conceivably support it.Having a 25 piece marching band in your living room is not possible but the "illusion" can be as long as you keep your eyes closed (my theory on the eye/ears/brain connection where one tells the truth and the other lies and means not beleivable at all.The never talked about "visual" part of audio reality
With the small scale performance,that is maybe a solo vocalist accapello or the singer/guitar player and in a larger room a piano or possibly trio you need
zero artificial enhancements as long as you can get the dynamics right which to me on the "realism " scale are
far more important than getting the tone right if realism is the goal.to add an effect to a room sized performance can only sound artificial since there will be no actual "space" to simulate !
So the DSPs all fall down by trying to make the ROOM sound like
surround instead of
removing the room boundries from the equation and creating "space" and without ever taking into consideration the actual music type and if it even fit the "this is it" model.
I
hate to single out a legitimate product in public for abuse but while the movie mode of Dolby surround can be very effective the music mode falls short and is comprimised.Then again they are far smarter than me so maybe I am off base on the "why".
rick don't always know which road to take but when he arrives at the destination no one needs to tell him "you are here"
