Hifi Man
- Jan 18, 2013
Okay, so just to clarify briefly, here are the specifics of your intended use:
- You plan on using the cans you get both at the computer and while working around the house.
- While around the house, you use an iPod as your primary source.
- You plan on getting a DAC/amp (our terminology for an external soundcard and amp) for use with your computer.
- You do not plan on using your external DAC/amp with your portable source.
If these are correct, awesome. If not, please correct me so we can keep moving towards the right answer. With that said, I have a few follow-up questions for you:
- Do you plan on ever using these with your cellphone or tablet? If so, what model(s) do you have?
- Which iPod do you use?
- On the computer or from a phone/tablet, do you ever anticipate the need for a mic? (I.e., will you use them for talking at all?)
- What kind of computer do you have? PC or Mac?
This will help us make sure we point you towards something that will do what you need in each scenario. I'll check back on ya tonight!
1. Correct
2. Correct
3. Maybe (only if the headphones can be enhanced with it, and it will take some time of saving up money)
4. Incorrect. I think it would be alright to have a portable amp for my headphones. I think it would be the best option, although, only if it truly enhances the performance of the headphones; then it's worth it.
However, I don't want to disclude the possibility of non amp driven headphones. I'd like to understand what the benefits would actually be, and if it's worth it.
My cellphone is a 3g iPhone. My tablet is an iPad. I don't anticipate the need for a mic. I have a PC.
I also use an iPod g1 touch, and a 160 gig iPod classic.
I think it's crucial to mention, the reason I'm seeking an upgrade is because my headphones sound very flat with death metal. I'm looking for headphones that deliver vibrant sound, that can handle extreme music, but also sound good with more laid back music too.
Awesome. Okay, let's dive in with a couple of quick provisos up front: first, finding a DAC for an Apple product is vastly more difficult and typically more expensive than a comparable unit for Android due to Appleextortionlicensing fees. With that said, there are a few units that will work with them-- but if you have an upgrade right around the corner, that might complicate things a bit. It seems like you're an Apple kinda guy, so I'm going to assume you'll be going with an iPhone for your next upgrade unless you say otherwise. Also, I'm an Android and PC guy, so there are going to be a lot of people who are vastly more knowledgeable than I, and I'll be writing solely from a bit of research and reputation. I'm going to make an effort to point out anything about which I'm unsure, but again, I'm no Apple expert, so it might be good to vet some of these ideas with somebody that has first-hand experience.
Also, to answer your question: while people can mean different things by the term 'punchy,' they typically mean it has better-than-average bass impact-- which is great for blast beats and double-bass beats of all kinds. It adds to the fun and engagement of listening to metal, IMO.
DAC/Amp Options:
VentureCraft GD-03: definitely the 'bang for the buck' winner here at $20. As it was made for the 3GS, you'll have difficulty using it with some other models, but for a product that was originally $200 and is now $20 and fits what you have... Hard not to be pleased. It seems to be an amp only, no DAC, but apparently the DAC in the 3G/S wasn't too bad, so you'd probably be okay. Don't think you'd be able to use it with a computer, but again... It's $20. If you can't figure out what you want, get this until you do, IMO. (Other colors seem to still be available if you're interested). Another HF'er posted about compatibility with other Apple devices here, for reference. Also, this thing is an external battery, so it can charge your phone. Neato.
LOD into external amp: a line-out dock simply provides a line-out to an external amp (if I understand it correctly, and I think I do). A lot of DAC/amp combo units can be used as amps only, which might give you some additional flexibility for using a single device for both your iPhone and computer.
VentureCraft GO DAP X: Way above budget at nearly $500, but works as DAC/amp for both an iPhone and computer.
Cypher Labs AlgoRhythm Solo: DAC only, very pricey. Highly regarded, but priced even higher. You'd need to get an amp to go with it too. Probably wanna skip it for now.
Fostex HP-P1: Also a budget-breaker at almost $700, but it's a DAC/amp. I think it also only works with an iPhone, not with a computer. Skip it.
Summary: if I was in your situation, I would probably just get a LOD and a DAC/amp combo unit that allowed for amplification only when being used from the phone and allowed for use as both a DAC and amp when plugged into your computer. There are quite a few of them, but I would highly recommend you check out the Meier Audio PCSTEP (here) or the iBasso D-Zero (here). The D-Zero is the best bang-for-the-buck portable DAC/amp I know of (I have one and bought one for my mom too), and the PCSTEP is the best sounding portable unit I've yet encountered (better than the Apex Glacier, iBasso D6, iBasso D-Zero, and O2/ODAC combo to my ears, and cheaper than all but the D-Zero when you factor in shipping). Again, though, the cans you're looking at presently don't really require an amp-- but you won't have to struggle to hear the improvement of a DAC/amp combo from either your soundcard or your phone. They make a pretty obvious improvement to the sound.
Headphone Options:
In short, you have tons. As a fellow headbanger (listened to Broken Hope's Grotesque Blessings on the way into work today, forgot how much I loved that album), I'd recommend the HD25, as it's just great for metal in general. The M80 is close, but I think the HD25 is just a bit clearer, and thus wins out in my book. I haven't heard all the cans recommended here, but I'd say that the Beyers are probably worth a look, as my T5p is my most listened-to headphone (not counting IEMs). I would guess (although I could be absolutely mistaken here, and would welcome feedback from anyone who has done an actual comparison) that the DT 770 LE would be a bit clearer than the HD25, at the expense of a bit of portability (in terms of size), isolation, and durability. The Momentum might be great, but mine hasn't arrived yet, so I can't speak to its appropriateness for metal. And of course, there are quite a few more...
TL;DR Version:
Lots of options, significantly limited by use of the Apple device, so I'd go with a LOD to a portable DAC/amp unit that can be used as a standalone amp. If I had to pick only one setup to recommend, I'd say LOD > PCSTEP > HD25 (or Amperior, if you find a good deal on one). This would put you a bit above your budget ($10 + $280 shipped + $100-150 used), but give you a great-sounding and very flexible setup. If you're adamant about staying under the $300 initial budget, I'd say LOD > D-Zero > HD25 ($10 + $109 [before shipping, about $30 to ship to US] + $100-$150 used).
I hope we're helping and not driving you crazy, bud.
"If I were to go all out, and spend 300-400 dollars then which one would I want?"
-As is customary in the world according to Head-Fi, spending more doesn't really solve issues generally, it just gives you more attractive options.In that range, something like the Momentum or the M100 becomes a more viable option, and you start to get close to another level of performance altogether with something like the HiFiMan (ha!) HE-400, which is pretty much universally praised as outstanding for it's price range. However, something like the HE-400 really does require amplification, unlike the other headphones we've discussed, and as a planar dynamic it needs a fair bit of current to operate. (Note: even my Audez'e LCD-2, which supposedly requires more current to sound great than the HE-400, can be powered straight out of a cellphone jack-- but you can tell the music just isn't anywhere near as lively, detailed, or engaging as it is with a proper amp). If you can stretch to something like an HE-400, you don't plan on using it portably (it's too big and isn't closed-back), and you can at least budget to get a better amp in the near future, that might be your best bet. Of the headphones we've discussed, I think the HE-400 would be pretty much universally considered to be the closest to the "high fidelity" ideal. Check out some reviews and see what you think. You can sometimes find them in the F/S section for $300-350, which would leave you a bit more breathing room in your budget for an amp.
Check back with ya later tonight![]()
None of the headphones you mentioned require an amp, some might sound slightly better but none need an amp to get the most from them. I am surprised no one suggested the MDR1R from Sony. Comfy as all get out with 2 great cables.
I guess the question is, am I getting the best sounding unamped, good for metal music, comfortable headphone for under 400 dollars? If not which one should I be getting? I don't want to disclude the headphones I literally just purchased already, but I'm curious to know because this doubt is very heavy on my mind.
