lennyr
- Mar 16, 2011
Has anyone tried the Avantree Clipper Pro? It looks interesting, in that it supports AptX - Low Latency, and is Bluetooth 4.2.
Giving this a necro-bump rather than starting a new thread since my question is related to the three flavors of aptX but don't see it covered so far.
I have a Bluewave Get that features aptX HD on order, in corresponding with the developer, he mentioned that the Get should be backwards compatible with regular aptX and aptX Low Latency (LL), it'll use the corresponding codec depending on the paired device and what is being played (e.g. if video, it should automatically use aptX LL).
I recently got the V30 and when paired with Mixcder's HD601 (which features aptX LL) it only connects via regular aptX. The V30 doesn't give any indication as to which codec is being used, I can only tell by the LED color on the HD601. This seems to indicate that either the V30 doesn't support aptX LL or aptX HD isn't backwards compatible with it. Would anyone know for sure?
TIA!,
Tim
@Dulalala - the V30 does in fact feature aptX HD as confirmed on aptX's site (https://www.aptx.com/products/lg-v30-smartphone) as well as by users (https://forum.xda-developers.com/lg-v30/help/aptx-aptx-hd-indication-v30-t3718127). I unfortunately don't have an aptX HD headphone yet so can't confirm on my own.
You go to Bluetooth Audio Codec in the Developer options and there you can establish which codec to use by default (if possible) and it displays which codec is currently used when you're currently using a bluetooth device. And there is other settings, like when you're using LDAC like me to decide between adaptive bitrates, prioritize connection, and prioritize quality.I've enabled Dev Options but would you mind telling me where can I see which codec is in use?
The V30 most definitely support Aptx HDThe V30 doesn't support aptX HD or aptX LL. Funnily enough though, the V20 does support aptX HD.
That's like listening to 2 different speakers , not to mention your confirmation bias.I’ve listened to the highest quality on the WH100XM2 and the same on my B&O H6 Gen 2 with wires, and the H6 produces a far superior sound than Bluetooth. Perhaps as was suggested when 5.0 is ubiquitous it will exactly the same as wired, until then I think not.
+1 to thisThat's like listening to 2 different speakers...
