A single speed motor could have advantages over a multi-speed one. As far as tray mechanism / (and motor maybe?) goes I've only ever seen 2 types; my ERC-3 and Oppo 105D D use the large size drawer/tray. (Edit: I forgot, there are some with flip-tops like Woo and Chord, I've never experienced this type and they may not be categorized as "tray" types. And, of course, the slot and rubber roller types found in cars).
My NuPrime CDT-8 uses the thin type tray and it seems more rigid and less prone to vibration-al issues, if that matters.
Both are single speed players but the NuPrime motor is dead quiet where the ERC is audibly noisy. Might not be an issue with speakers
but with open back phones and quiet passages in classical works could be intrusive.
On the other side of the coin, the ERC remote is a nice, full featured affair and both it and the button controls on the ERC work flawlessly.
The NuPrime remote is small and laid out un-naturally, to my way of thinking, having used remotes on CD type players going back to the early intro of laser-disc and DVD /CD,
And, some of the buttons on the unit don't respond and the remote buttons usually need to be pressed twice to initiate a command, but not always (small infra-red window?).
The NuPrime remote also does not have keypad entry so if you want hear track 18 of 22 you'll have to scroll 1 track at a time (either forward or backwards) to get where you want. Maybe there is some advantage to this but I can't imagine what it might be.
The NuPrime is a true transport only with digital outs while the ERC has both digital outs and analog outs from it's internal dac, and the ERC was a significantly cheaper, but a much larger physical box to deal with, probably not desk top friendly.
But, I'd most likely buy a Schiit spinner just to have for back-up if not to outright replace one of the other two I already use.
