Ok chill. If you say so then good for your setup.
What a long, strange trip it's been -- (Robert Hunter)
- Thread starter Baldr
Pietro Cozzi Tinin
It's just that they're both huge problems in their own way with different solutions.Ok chill. If you say so then good for your setup.
I was not offended in any way.
earnmyturns
If you connect the outer barrel of its DC power plug to ground it drastically reduces the high impedance noise the switch passes on.
Intriguing... When you say "ground the outher barrel", what do you ground it to? 1) switch's case, or 2) the ground of the AC power side?I did as you described.
Today I did the ground trick.
The difference in sound was not even a bit modest.
It was huge!!
It's the background noise (that you not even knew was there) one eliminates this way.
A real upgrade and a must for everyone who plays digital over ethernet.
DO IT!!!
Pietro Cozzi Tinin
I grounded to the AC power side.Intriguing... When you say "ground the outher barrel", what do you ground it to? 1) switch's case, or 2) the ground of the AC power side?
So took a Schuko plug (EU) and connected the cable with that.
The Powerblock you see is network only so there's no audio plugged in that.
earnmyturns
Thanks! I have my audio systems already on separate Furman power distributors, and I have the same switches you do. I guess a little weekend project...I grounded to the AC power side.
winders
The AC ground. The SMPS of the switch uses a two-prong plug (at least in the US) so there is no ground on the chassis. To make my ground, I used a ring terminal of the appropriate size on the DC barrel connector and ran a wire to a banana plug that I then plugged into AC ground. Pietro’s method of using a full plug works great too.
winders
I had all data go via the same router.
Now the audio part is isolated with the switch, which made a difference in itself yesterday evening.
It was huge!!
DO IT!!!
Awesome! I am glad it was a noticeable improvement.
Paladin79
Previously MOT: Cables For Less
I have never noticed much of an issue but this is fascinating and I may have to check it out. Few days go bye without my learning something new within electronics or cables and you are certainly to be commended Winders for taking the time to explain this.
winders
Keep in mind this "trick" does not provide benefit with all switches. The Netgear GS108 is a switch where it does make a difference. This information came from John Swenson. He is UpTone Audio's product designer and I believe he does work for Sonore as well. I found the information useful and am happy to pass it along.
CAPT Deadpool
I've heard ground hum before but my Mimby to Jotunhiem is dead silent on the hiss/ground hum angle. All I hear is the music and some times my old enemy Tinnitus.
winders
This switch "mod" has nothing to do with ground hum or ground loops. It is about reducing high impedance noise that would otherwise be passed on by the switch.
Paladin79
Ok thanks, I had skimmed some of the info and I was going to go back and reread it when time allowed. I have specific areas of interest but things like switches and routers I let my son recommend to me since it is more his field. Generally when he visits he just looks at my system and says there is something better out there and runs out and buys it and installs it. Similarly if he is getting new audio gear and I show an interest, he generally sends me one as well.
Superdad
Member of the Trade: UpTone Audio
- Apr 14, 2015
I asked UpTone Audio for an update and got the following answer:
Hi Pietro:
I did not know you would be posting my e-mail reply. I assumed from your query that you had already read a bit about our in-development EtherREGEN over on the CA forum, But since I see word of it might have just come from a mention here at Head-Fi (not my usual hangout), perhaps a couple of links to greater detail are in order.
https://www.computeraudiophile.com/...tails-please-dont-ask-too-many-questions-yet/
and an update post made more recently,
https://www.computeraudiophile.com/...udio-streaming/?do=findComment&comment=860167
John is also developing a sophisticated, multi-board measurement system that injects a specific jitter pattern marker (he calls it the Golden Gate Bridge as the marker resembles the Cisco logo) into Ethernet or USB upstream clocks, then through a DAC, then captures with high-speed 32-bit SAR A/D converters, and runs it through wavelet analysis s/w (sort of a 3D FFT). If/when the marker shows up in the analysis of the analog output, that will prove that the phase-noise fingerprints of upstream data clocks (as well as signal integrity modification by USB cables, etc.) can indeed make it through. Such could blow the doors wide open--showing the first real measured validation (at the analog output; we already can see a lot with tests such as eye-patten in the digital domain) of what so many report hearing with cables, USB decrapifiers, Ethernet switches, etc.
Of course then we will show how our specialty isolation blocks the marker.
Sorry if all this is off-topic for this thread. I really can't tell from the thread title what the topics are here. But with almost 9,000 posts I guess it wanders a lot anyway!
--Alex C.
riffrafff
Thread topic? What thread topic?
Ripper2860
Yep. This thread has most certainly been a long and strange trip ...
Total: 6 (members: 0, guests: 6)
