ljnew
- Dec 24, 2015
BTW... if you notice in that pic above... the W80 nozzle is at a little different angle from the housing than the W60. Not sure why they did this. But that little angle caused me a little bit of a problem at first. I like to use the original triple flange tips from earphones plus, which have a wider bore opening into the ear than, say, standard Shure triple flange (earphones plus stopped making 'em like this... ashame... but I bought a stockpile of them when I found out, so I'm good). Anyway... the earphones plus triple flange has a shorter stem at the earphone side than the Shure triple flange. So while they worked great on the W60 for me... that little angle on the W80 caused the earphones plus triple flange to no longer reach far enough into my ear to make a good seal. The first time I put the W80 in... I kept having to push them into my ear, trying to get a seal... until my ears started to hurt a little. I finally saw the problem. I put a little snippet of a black triple flange tip stem on the W80 as a spacer next to the earphone... and then put my normal triple flange on... and it works great, so no problem now. I just can't help but wonder why Westone changed the angle to that extent on the W80 from the W60, which causes the housing to stick out a little more towards the ear side of the earphone. It probably won't affect most people's use for their particular preference in ear tip. But for the specific triple flange tip from earphones plus I particularly like... the ear tip worked perfectly on the W60... but I had to make that minor little adjustment for the same ear tip, to use them on the W80. All good, now though, and I'm loving the W80.
FWIW... I also like to use the Sensorcom Earportz eartips sometimes, and those worked fine on the W80 without having to use the little rubber spacer on the nozzle.
Respectfully, I'm not going to play with a triple whichamajiggy when i paid $1500. No pun intended.
Had same issue, used the foam tips at expense of clarity and treble but increased isolation.....
