Like I said... none of my Westones have ever had a problem. Not sure how someone can continually, repeatedly break them... unless you're just not careful. Or maybe from popping the cables on/off so many times. I tend to leave whatever cable I'm using on them, and am not constantly disconnecting/reconnecting them. Maybe that's the difference.
Then you've been lucky.
Lots of people have had problems, and it has nothing to do with not being careful.
But saying Westone is notorius for build quality issues is, at the least, misleading.
If you read through the Westone threads on this forum, you would see that there are lots of comments about the build quality and connector issues.
I've seen comments on reddit about Westone build quality, and reviews on Amazon mention build quality issues as well.
I would bet there's many more users who've never had problems than there are that have.
I would hope that there are more people who haven't had issues, than have had issues.
Saying that there are issues with the UM Pro and W range doesn't mean that 100% of people have had a problem but, even if only 25% of people have, that would still be too many.
If Westone had very many issues and people complaining... they would have changed it.
Well they did have a lot of people complaining, so they did have to change the MMCX connector.
The MMCX connector allows the earphone to rotate 360°... as MMCX connectors are designed.
Yes, I'm aware that MMCX connectors are designed to turn 360 degrees.
But is the connection quite secure (i.e. it takes a little bit of effort to turn them) or loose (i.e. the earphones will swivel around 360 degrees without any effort)?
My first pair of W60 had loose connectors, and the earphones would swivel round without any pressure. After 6 month the sound started cutting out in the left ear.
My replacement pair have a much more secure connection. Westone have updated the MMCX cable, so that the black plastic around the connector is a bit longer and there is no gap between the cable and earphone.
With the ALO cable, that comes with the W80, there's a gap between the cable and earphone. I'd just like to know how secure the connection is.
If is is secure, and the earphones don't swivel on their own, then I'll be tempted to get the W80. If they do swivel on their own I will wait for a few months to see if there are any reports of people finding the sound cutting out.
