- May 10, 2015
Growltiger - Based on what you are saying I would simply say IEM's are not for you and stick to headphones. You have heard the best and trashed it relentlessly. Save your money and stick to headphones or full sized traditional room set-ups.
Perhaps one exception is to try IE800. Very different from the Westone sound. Insane resolution and detail
@Spyro: I decided to follow up one other possibility, which is to do the obvious thing and try the logical upgrade path from the SE535 to the SE846. I have found that this is disappointing in complementary ways to the W60. Clarity is much greater, and the creamy coloration of upper winds and strings using the blue filter is very attractive. But, even then, everything below about 300Hz is very muddled. With the white filter, which is supposed to deal with this problem, the higher frequencies are harsh, and there is actually less clear audible bass (for instance orchestral double basses, when they have a rare exposed line) than on the 535. If there were a filter modification that reduced the amount of bass spread while leaving the upper end as it is with the blues, the 846 might have worked for me. Thanks again for your suggestions.
