After about 2 months of constant use, my Westone 3 cables have become damaged.
Description of use:
I usually take a bus and then train to my work place, around a 45 minute commute and back each day. I wore the headphones through the back of my neck, running down through the side and then to a pocket where I keep my Iphone 3 G. There is always some tugging along the cable, because there is no clip to hold the cables from tugging the headphone from the back side.
Yesterday, after I was handling the Iphone, I noticed a muffled sound. It was almost as the singers were singing through a tunnel or something. I increased the volume and the same effect took place. Then, I though, perhaps the Iphone isn't giving enough juice, it was running just below 10% charge.
When I arrived home, I did notice that the sound had returned to normal. I was wondering what happened. When I unplugged it from the Iphone, I used my son's Nintendo DS to see whether the headphones had any problem, they worked fine.
The day after, I did my commute and it headphones sound great. In the end of the day, when I was returning home, the same weird tunnel sound effect happened again. Then, I began to wonder which part of the headphone might be the culprit, then, I also though that it could be the Iphone.... At home, I got another Ipod, a Nano version II to test the headphones. The same happened. Then, I unplugged the extension/volume cable of the Westone 3s, and plugged it directly to the Nano. The same sound returned. Then, I began to tug along the different sections of the Westone 3s wires, wherever I believed there were faulty connections. I noticed that when I pushed or bent the connections between the wire and sections where the plastic Y connected, the sound either came back fullrange or continued sound echoey with tunnel sound. My verdict was that although visually it was okay, there must be a faulty or defective connection in that section.
My other experiences with in the ear headphones were with Etymotic Research ER-4Ps, a pair which I have owned for approximately 5 years. In my years of ownership of the Etys, I had to send them to the factory twice, once because of a wear and tear of in the bendable cable wire close to a plug in base which exposed bare copper wire thus failure making any sound in one headphone driver, to which, Etymotic replaced the cable. The second time I sent the Etys to the factory was because of the plastic flanges cracked at the base, which the factory simply replaced the older ER-4Ps in red and blue, towards the new black version with new cable. All this was done free of charge and they did not even ask for a receipt. All I could say was that the warranty/customer service for Etymotic is outstanding. Their turn around times are also very quick, within 5 working days.
Now, I am keeping my fingers crossed that Westone will also do a very quick turn around on the earphones and their fixing. My verdict in my Westone 3 ownership is that the cable is more delicate than it seems or perhaps that I got a defective cable that had an unusually short life span in the field.
Paul
