My Milo the hiss is hard to hear if any maybe the references improves with the different components used.
Wells Audio Milo - Impressions And Discussion Thread
- Thread starter ufospls2
The Milo does it for me powering my 1266 TC like a champ. The WA33 was boring with my edm. I got rid of the Woo. I'll say PRAT, speed kinda warm powerful bass clean and does it in a small package.
Astral Abyss
Yeah you shouldn't hear any hiss on the Abyss. My Diana is perfectly silent too. It's only the very sensitive cans. The Milo is a bit too powerful for them.My Milo the hiss is hard to hear if any maybe the references improves with the different components used.
No I don't hear hiss on any headphone. Like the Empyrean or Thekk.Yeah you shouldn't hear any hiss on the Abyss. My Diana is perfectly silent too. It's only the very sensitive cans. The Milo is a bit too powerful for them.
wormsdriver
I think it's more on dynamic drivers
I'll try my VC. only thing i can hear is a quit hum so lo that I need to focus really hard and still have a hard time. Maybe Jeff was wrong and there is attenuator which I did ask about when buying he told me not to. My concern was getting use out of the volume knob I get to 10 11 and it's loud on my higher sensitive cans 12, 1, 2 on the 1266 and HEDD
wormsdriver
Yeah, it shouldn't be a problem with zmf cans. Hum is not really a problem on my 300 ohm hd800 either
mwhals
- Jul 26, 2015
My ZMF headphones are quiet on Milo. No hum or anything other than beautiful music.
Yes, Milo is dead quiet withe VC. When there is no music of course
spw1880
Hi,
I just put money down a new stock milo from a headphone store for my verite opens, i didnt get the khozmo and vishays. Since the store was a hour flight away and we are still in stay-home-if you-can status i did not go to audition. Funny enough the store owner insisted i buy the non khozmo vishay one as it will be more forgiving towards the music i like which is edm pop and rap, he had both versions in store..after reading a number of posts from happy milo owners, should i be worried about volume play being too narrow?
Thanks
Thanks
jamesng45678
- Feb 16, 2014
You could try using the milo with a power conditioner such as the one i am using Plixir Elite. There is totally zero hiss and background noise. Highly RecommendedMy Milo the hiss is hard to hear if any maybe the references improves with the different components used.
jamesng45678
- Feb 16, 2014
Do not plug your milo directly into the dac or streamer. You could use a pre-amplifier in between your dac and milo and that could improve the sound significantly as well as control the volume of your milo. Hope that helpsHi,
Thanks
wormsdriver
Even with more sensitive cans?You could try using the milo with a power conditioner such as the one i am using Plixir Elite. There is totally zero hiss and background noise. Highly Recommended
jamesng45678
- Feb 16, 2014
I use my HD800, HD800s, audeze LCD 3 and Aeon flow. There is zero background noise or hiss. The sound is mainly from noisy power supply or ground loop issue. The easiest way to solve it is to ground all the audio components together and connect together.Even with more sensitive cans?
Can you suggest some specific model of pre-amplifier?pre-amplifier
