Cannibalia
Thanks for this, I bought the unit here, I believe it’s completely stock.
Congratulations Ken. How are you enjoying the Milo so far?Bought mine, upgrade from a jotunheim multibit To a d90 with a milo upgraded. W/ hifiman Arya
4 | I've heard it's a dream pairing, waiting for payment to clear |
There are a couple different versions of the Khozmo attenuator that Jeff uses. There was one that had a more gradual ramp and one that was more aggressive. Either way, there is a lot of gain on the Milo, so it generally gets loud quickly.What volume do you guys listen at with the kozmo? Curious if this amp is on the quiet side as far as volume goes, or loud?
Good point, thanks.Yes, the Headtrip is more powerful, but it does have the same DB of gain the Milo has. Your best bet is email Jeff Wells and explain the situation. I would have thought the Milo, if it has the stock gain of 30db and not the attenuated version, would be powerful enough.
Forgot to write about replacement. Everything went ok and I can drive speakers.nowHi,
didn't get any answer from Wells Audio but got one from Arek Kallas, Khozmo's manufacturer. I was told I need to replace 2 vishaz resistors, from 47K to e.g. 10K.
Just ordered them.
