Aug 12, 2014 at 10:43 AM Post #16 of 33
The magni/vdac works fine with the momentum. Will probably work the best if you ever want to upgrade to planars for example.
Aug 12, 2014 at 1:12 PM Post #18 of 33
A portable unit just to support the listening out of Office is overkill?
I guess only you know that. I doubt the difference between magni and e12 will be major at all, except with hard to drive cans perhaps.
Aug 12, 2014 at 1:31 PM Post #20 of 33
The Magni is definitely a better headphone amp than in the E07K.
I'm not an Apple person, but I don't believe you can bypass the iPhone 5 DAC very easily. With iPhone 5, you need to look into lightning adapters, and I think DACs that connect to the iPhone are specialized items that have to pay Apple a licensing fee. In other words, get ready to spend some money.
Aug 12, 2014 at 1:37 PM Post #21 of 33
If it's an iphone 5 as source (?), how are you even going to use any of the mentioned products?
Aug 12, 2014 at 1:47 PM Post #22 of 33
Which is why I originally mentioned the A200p. It's the only unit so far mentioned that is both amp and dac and can be used natively with the iPhone5 + stand alone as a USB amp/dac for PC/lap-top. If you get the US version it'll even drive up to 600ohm cans.
Aug 12, 2014 at 1:48 PM Post #23 of 33
The OP also has a laptop. I think the best option might be to explore the iBasso DX50, FiiO X3, and FiiO X5 if a portable solution is a must, too.
Aug 12, 2014 at 1:49 PM Post #24 of 33
That's good to know. So Beyer paid the licensing fees. :)
Aug 12, 2014 at 1:50 PM Post #25 of 33
Yep. Comes with a lightning cable and everything.
Aug 12, 2014 at 4:57 PM Post #27 of 33
How would you think the Meridian Explorer, HRT microstreamer and Audioquest Dragonfly 1.2 would compare to the V-DAC/Magni combo (knowing that I compare different segments)?
I don't think they would in terms of headphone amps. Fairly powerful desktop amp that requires AC power vs. USB powered devices.
I have no idea about the DAC components.
Aug 12, 2014 at 5:43 PM Post #29 of 33
Looks like I'm getting the Magni. Or maybe the Vali?
If you know you like the tube sound better or just want to try it. I don't personally prefer hybrid solid state tube amps over comparable solid state amps. Some people like that; some don't. Often not the same as the full tube sound from OTL amps. Also, you can'd do any tube rolling with the Vali. The Magni also seems to have a big more power.
Aug 12, 2014 at 5:53 PM Post #30 of 33
Very greatful for all your answers!
