Yep, my brother-in-law is CEO of his company branch in China, he is return home next week - nothing to do during Chinese New Year, Shenzhen must be empty!
My second Walnut was canceled today by the eBay seller I ordered it last week. There are no more Walnuts available until the factories open up again.
To all whose orders got cancelled - I would start checking as soon as factories open back up after Chinese New Years, as it's pretty clear this is a hit around the globe. =)
Some people have reported loose usb connectors, usually a solder joint not strong enough to handle the force of cable plug in, removal, you get the point
Probably partly due to a sudden surge in interest made QC be a little worse than it was...?
If you have a soldering iron, i would - after disconnecting & putting battery somewhere else - touch up the solder joints that hold the usb plug in place.
I discovered that Raytheon make a low noise version of NE5532, it's called RA3678C, I ordered to see if it sounds any different. It's a bit more expensive than NE5532 but still cheap at $2-3.
