Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
Dec 20, 2016 at 8:18 AM Post #511 of 3,634
Happy Birthday and celebrate .I didn't expect that Walnut V2 will work so well with the laptops, I will have to try it myself once they ( 3) get here . Don't forget to do that modification on the Koss headphones, won't take you long and the sound will change in better.
Is this mod just enlarging the pre-existing holes? If so, how large?
Dec 20, 2016 at 9:20 AM Post #514 of 3,634
(A quick note on Walnut durability: let's just say if either of my Walnuts had screens.... they'd be broken right now. They have both taken more falls than I care to admit and both are still 100% perfect.)
Happy birthday vapman. Wish all the best for you. Don't you want to do a give away your bursson v5i walnut for your birthday? :grin:
Btw, is there indonesian here?
Dec 20, 2016 at 9:21 AM Post #515 of 3,634
Not enlarging the existing ones, making new holes 18x4 mm each grill.
Dec 20, 2016 at 9:47 AM Post #516 of 3,634
Walnut vs. Alien...
Alien has less background noise (but Walnut isn't bad at all)
I would like to say Alien has slightly better separation, tighter bass response, wider sound stage and a less HF roll-off. Changing op-amps in the Walnut may narrow the slim margin Alien is winning by. Otherwise they are fairly similar and all the aforementioned is only by a little.
To be fair, Alien has hundreds of hours on it and Walnut is around 20hrs, so not sure if burn-in will effect any of the above. My wife uses Alien for her gym rig so I haven't listened to if for a while, it was nice to hear again.
well that tells all about wallnut, i cant wait for my unit to arrive :)
Dec 20, 2016 at 2:31 PM Post #519 of 3,634
My Walnut is still in Taobao purgatory. Does anyone know what the below means? Should I be doing anything? Thanks.
Dec 20, 2016 at 2:39 PM Post #520 of 3,634
I used Mr Tao. Seems to be easier communication.
Dec 20, 2016 at 3:47 PM Post #521 of 3,634
I would consider trying to cancel my order and ordering it again somewhere else, but I'm not even sure how to cancel it lol.
Dec 20, 2016 at 3:59 PM Post #522 of 3,634
That might just put you further back in the line.
Dec 20, 2016 at 5:55 PM Post #523 of 3,634
So it is confirmed that Walnut v2 is the best DAP for listening to Gucci Mane's Christmas mixtapes?
