very awesome, hopefully the usb port doesn't get too hot during charging ever
i don't think so.. i didn't pay attention but i should check it, thanks
Another one more Walnut here. I got it 5 min. ago . It came with the famous chinese card, 2x 3.5 mm jack wire, charge wire and a micro sd card reader.
I just played it 1 min. and happy with the sound, very clear. Thinking to buy it another one when they sell it again.
This sounds like a grounding problem.
I don't know that seller, maybe other one could you answer better about. But.. CKLewis have no one Walnut available now but this seller have 991 available ? I donn't know what to think...
yes it is a constant buzzing static sound that can still be heard when the music has been paused, and adjusting pot or digital volume does not affect this static noise.
to put it into perspective, it is louder than the infamous static noise from my Fiio E11.
so it is safe to leave it plugged in and let it burn-in through the weekend right? volume is at 10 o clock position with max digital volume.
what is your phone, it's impedance and sensitivity values?
I think I'll go with this player too but where should I buy?.. Should I wait for CKLewis?
I would say wait unless you find someone wanting to sell theirs used. There won't be any new ones made until after Chinese New Years.
I know but what about the other seller on AE?
finally i could find enough time to mod my walnut;
here is my first mod;
changed chinese power supply cap to panasonic NHG 1000uF 25V (upper right corner)..
it's about 5 mm taller than stock one, so i had to put it over micro usb socket..
next, will try to change potentiemeter to an alps rk097 type..
