Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
post-13210343
Post #1,607 of 3,580
music4mhell
  Is it ok to have the Walnut plugged in while playing music to break it in?
I am using Walnut to burn in my HD6XX with Cardas cable and Cypherus CAX from last 10 days always plugged in by powerbank :)
post-13210363
Post #1,608 of 3,580
Dark Helmet
Thats what I figured. Just wanted to make sure. My Shanling M2 says not to have it plugged in while playing.
post-13210382
Post #1,609 of 3,580
music4mhell
Good thing about Walnut is that you can burn-in 2 earbuds/headphones at same time !
post-13210914
Post #1,610 of 3,580
ER4S
Previously known as mohandas
I also found these sellers on AE (don't know anything about them):
http://aliexpress.com/item/New-DIY-MP3-V02-Professional-Lossless-Music-MP3-HiFi-Music-Player-Support-32GB-TF-Card-Expansion/32782406664.html
https://aliexpress.com/item/New-DIY-MP3-V2-Professional-Lossless-Music-MP3-HiFi-Music-Player-Support-32GB-TF-Card-Expansion/32777433658.html
post-13210974
Post #1,611 of 3,580
noknok23
Netherlands
Netherlands
I read also on some devices manual that charging without using it is preferable. It's general advice, if you want a healthy battery for the long term, is better to not use wile charging. It's more "clean " and less stressful for the battery. But I'm not sure it is worth the hassle. I put it on the same level as safely eject USB. Doesn't really harm if done from time to time but can be bad on the long term if it become a habit :sweat_smile:.
On a side note, noise floor is increased when my walnut is plugged in.
post-13211551
Post #1,612 of 3,580
Dark Helmet
Just curious, after breaking in the Walnut (no pun intended), do the low mids become a bit more prominent and does the speed of the bottom end impact improve?
post-13211585
Post #1,613 of 3,580
vapman
Member of the Trade: bhobuds.com
Subjective really, i would say slightly yes to the low mids and yes to the speed of the sub bass. however an opamp swamp might likely change the sound more than an opamp would. i  am still waiting on delivery of other 5532 variants to test those against the TI 5532 like comes with the walnut,
post-13211689
Post #1,614 of 3,580
Dark Helmet
I will try and stay posted to see your results.
post-13211989
Post #1,615 of 3,580
Dark Helmet
Does anyone else have their end panels on their Walnut stick up higher on one side than the other?
post-13212273
Post #1,617 of 3,580
endia
istanbul
istanbul
I tried the following, and I can hear the noise floor on all of them, some more obvious than others, of course.
their specs taken mostly from "theheadphonelist" IEM review thread.
Xiaomi Hybrid
impedance: 32
sensitivity: 101
Monoprice 8320
impedance: 32
sensitivity: 96
KZ ZS3 (spec from gearbest)
impedance: 18
sensitivity: 106
NuForce EX600
impedance: 16
sensitivity: 100
Xiaomi piston 3
impedance: 32
sensitivity: 98
it looks most likely a grounding problem as @jpciii stated..
if you're handy with soldering iron, you may reheat solder joints on 3.5 mm female jacks'. any imperfect joint may cause noise..
post-13212288
Post #1,618 of 3,580
endia
istanbul
istanbul
I havent open up my Walnut yet, but could you please advise if the power supply cap you replaced is of same rating or different?
and cant wait for your update on your pot replacement!
I replaced with same rating but you can change with any higher rating one as long as it fits to the case..
post-13212701
Post #1,619 of 3,580
nick n
Voltage rating you mean.
Capacitance value rating  I suppose you could experiment, it might affect the sound, think it does.
 I forget who posted about that already though losing track of things in here.
post-13212913
Post #1,620 of 3,580
vapman
@macky112
Try swapping to an OPA or AD opamp to lower the noise floor to an inaudible level. if you pm me your address i will mail you one;
