Airlight
- Mar 17, 2014
Thanks man, I appreciate the advice. I've noticed some subtle differences after around 50 hours of burn-in. Mids seem to be getting a bit clearer and less muddy overall. Not sure if I'm just getting used to the sound of these as time goes on lol.
Brain adjustment is the very likely cause. It's like working in a sewer. If it's your job, eventually it's a mild inconvenience, where the first time the smell hits you it'll knock you out.
... you know, if a sewer was sibilance and recessed mids...
That said, try different tips, I can produce quite different tonalities with different shapes and dimensions of tips. One pair might be very sharp, another sounds much fuller. Definitely try any tips from other IEMs you may have that fit the stem.
