Pharmaboy
when i owned my 281 i was able to listen at -12 balanced with the abyss 1266 phi and even the susvara
This is all about system gain. I use my V281 both for headphones & as a system preamp.
- If the component upstream of the V281 (ie, a DAC) has high gain--or components downstream want higher gain (ie, planar headphone like the Ori; inefficient amp for speakers)--the best tactic is to dial in gain as needed for system gain-matching
- The V281 has separate dip-switchs for headphone out vs line out. IMS the ideal setting is -12 dB for both. But if I need to have one output higher or lower, I can easily make it happen
Add in the separate muting for headphone out vs line out, and you see just how flexible the V281 is...
