Another nice, two XLR out on Senn.
V281 has four amplifiers for single 4-pin XLR output. Does Senn have eight amplifiers to drive two XLR outputs?
SE outputs in V281 use outputs from different amplifiers (but they are the same amplifiers, which used to drive XLR output).
In this case the left output is out of phase, and the right output is in phase by default.
You can switch SE/TRS outputs to balanced mode with the jumpers inside the amp.
In this case you can connect the headphones in balanced mode with the corresponding cables to TRS sockets.
See manual for details.
There is interesting thing which may affect the comparison when both headphones are driven simultaneously.
According to my experience, LCD-3 may be affected by reflections of the room when the playback volume is high.
This may happen when you have reflective room, and this will at least reduce detail, making the sound "cheaper".
This may be your case too, when you compare two open headphones, which may affect each other.
The one major gripe I have with the V281 is that the MAGIC out of the XLR out is not matched in the SE out.
Actually, I think you can minimize the difference for some/most headphones.
SE outputs (on any amplifier) have one major drawback. When you have 3-wire connection, the impedance of the cable (common wire) will increase the crosstalk.
For example, I have relatively cheap Shure SRH840. The stock cable has 1.5-2 Ohm on the common wire.
This increases the crosstalk to -25 dB (!). When I changed the cable to something like 0.1 Ohm on the common wire (thick cable) the crosstalk reduced to -60 dB for one channel.
Another channel shill has -50 dB crosstalk, because of internal connections of the headphones, but this is not bad already.
The crosstalk increased to such levels (-25..-35 dB) may lead to more harsh sound (especially in the areas where the headphones itself have some problems).
For Shure SRH840 this is 6-7 kHz area. But finally, after changing the cable, the overall transparency is increased too.
I think this is especially important with the "true to source amps", which have no added smooth, liquid, pleasant layer or some other kind of coloration.
