sahmen
- Apr 6, 2014
2. Re balanced vs RCA/S.E. outputs, I would love to be able to run these outputs simultaneously: with balanced output pair directly connecting to my balanced-input powered monitors; and SE/RCA outputs going to the SVS SB1000 sub. However, the Violectric manual advises against this, saying sound may be degraded as a result.
Have any of you used the balanced + SE outputs simultaneously? If yes, could you hear any degradation from doing so?[/QUOTE]
I have done this, but only when the V281 is operating in Pre fader/fixed mode. Because I want the sound from the Yggy (DAC) to remain in the balanced/analogue domain through the V281 and the XmC-1 processor without any processing (such as bass management) being done by the XMC-1 upstream, I assign the XMC-1 to the all analogue Reference Stereo setting, and allow the RCA output from the V281 to forward the same unaltered INPUT signal (prior to level control) in full range mode to the subs (which do the bass management)...
True, I have read the part of the manual which warns about the possible slight degradation of the sound when both balanced and unbalanced line outputs are engaged at the same time. However, I have also assumed (rightly or wrongly) that since the v281 is hardly doing any processing to alter the sound when operating in that Pre fader/fixed mode, and all the heavy lifting is being done upstream by the Pre pro and the powered subs (bass management) and downstream by the DAC, there is little to no risk of the forwarded signal from the V281 being compromised. I have not tested this hypothesis in any rigorous way by AB'ing the results in SQ, but from what little testing I have done, I know that I definitely prefer the sound of the system with the V281 hooked to the subs.
Today, I removed the V281 from the chain so that the Yggy can feed the pre pro directly, and noticed no marked improvement in the sound, except for the fact that I was missing the low end that the V281's connection to the sub makes possible. Next I am going to compare the sound with and without the sub connected to the SE/RCA output of the V281 in "pre fader/fixed" mode and find out if I can hear any difference beyond the missing low end sounds contributed by the subs.
Of course, I am sure I am going to prefer the sound with the sub engaged via the SE/RCA outputs, but I wish I could be more rigorous in my testing methods than that... For example, I am making all the performance evaluations by ear, but it could be that the "possible degradation" they're referring to is the kind that is easier to see through measurements and graphs, rather than actually hearing. That is always possible. I shall also send an email inquiry about this to Violectric/Lake people in order to find out what they say.
