FumblingFoo
I have a quick question about the amount of power the v281 is able to deliver. Obviously I don't plan to listen any where near the max power the v281 is rated to deliver; I'm simply curious about what the testing is showing. So, the maximum input level for the amp is +21dbu, right? My v850 is set to deliver +18dbu balanced into the v281. For the test I had the amp set to +14.5db gain (6db + 12db pre-gain set). I used the Beyerdynamic T90 headphones 250ohm with a sensitivity of 102db/mw.
So, the v281 is rated to deliver I'm guessing around 4000mw per channel @ 250ohms balanced, right? That translates to about 2000mw per channel unbalanced, right? Well, at 2000mw the max spl should be around 135db, but by running the headphones with the volume at -30db in foobar2000 and the volume pot cranked all the way up on the v281, I was getting compensated max db figures around 140db (up to about 142db) out of my spl meter, which puts the per channel power at about 6300 - 10,000mw. I think I'm getting accurate measurements positioning the meter right next to the transducer, because listening levels become slightly unpleasant for me right at around 85db measured volume (the threshold for potential hearing loss) in the same position, and listening at 110db measured volume is EXTREMELY loud and very uncomfortable (120 db spl is supposed to be the threshold of discomfort, but a chainsaw at 1m is pretty uncomfortably loud too) . Also, even though the inner part of my ear canal is further away than the measurement instrument, the mass of my ear and skull are capturing a wider field of sound more efficiently than air from the transducer and concentrating that on my eardrum. Still, though, my methodology could be flawed and the actual spl a couple or so db lower.
I'm not about to field test that amount of power into my headphones, but the data presents a bit of a contradiction. Even with the extra 2.5db of power over what the manual specifies for the pre-gain, technically the v281 is running .5db within its limits because the signal I'm feeding into it via the v850 is 3db below max spec. So, the question is, will the v281 indeed deliver 6300mw per channel unbalanced @ 250ohms, or will the amp clip / severely distort or are my measurements just too loud?
