PrTv
My current setup is quite similar to your diagram.I'm looking to set up my V281 LE as a pre-amp for both a Marantz 2230 Speaker Amp and a Headphone Amp (Icon HP8 or DNA Stratus/Starlett) in my living room. My goal is for the V281 to be fed by a DAC and to pre-amp both amps WHILE having the V281 still available as a headphone amp. I have certain headphones that pair better with the V281 and others that will pair better with the other amp. Is this achievable?
A rough diagram is below.
Sorry if it is a bit busy. The dotted RCA lines from the DAC to Marantz/TubeAmp represent an alternative path if the V281 cannot act as a pre-amp for 2 sources.
V281 is connected to May KTE
V281 XLR out > Tube Amp (power amp) for my Susvara
V281 as a headphone amp for Utopia / VC
It works great!
[Euforia is connected with my May directly though]
I think you will like the flexibility as you can separately setup different gains for XLR/RCA and headphone outputs.
On the V281 serving 2 sources as a preamp, from my memory, you get sound out of both XLR/RCA but it sounds better with only one type of connection at a time (shared output).
