andromeda1954
- Oct 12, 2014
The stepped remote control is only useful if you listen to a HP not nearby the v281.It will giveIf I may ask, what makes the stepped volume remote so superior to the cheaper one? I am asking because there are some posters who make it sound as if the stepped volume control, somehow gives the V281 a sound quality boost that is superior to what it provides with the cheaper remote volume control option, and that is what I am having a hard time wrapping my head around. I mean this equation : stepped remote volume control = higher sound quality?? In my own personal case, I went for the cheaper version of the two remotes, because my impression was that the advantage of the more expensive one simply lay or lies in providing access to a wider range/variety of volume levels; an access, if you will, to a more finely calibrated process of volume control, as opposed to providing an improvement in sq per se (which I still do not understand).
That said, it was never a problem for me to find the appropriate volume level on the V281 in any situation by simply controlling the volume manually. The remote control was simply to enable me to do that same manual controlling from my listening position without having to make any unnecessary trips to the unit itself. The funny thing is that once the ideal volume is set for a particular headphone (which is never a difficult task to start with), I rarely find myself needing to alter that volume level, so the remote actually sees very little use time, (as compared to say my tv remote) , especially, since I can't even use it to power on the V281 or power it off after use. The only time I need to switch volume levels or settings on the v281 is when I change headphones (which I do not do very often), or when I have to set it in pre fader fixed gain mode. For such a relatively limited frequency of use, I thought the cheaper remote version was more than enough for my needs, which is why I did not go for the more expensive one.
With all that said, I still do not understand why some people seem to associate the superior volume control ability of the more expensive remote with superior sq. I am genuinely interested in knowing the reason, because if it is indeed true (and I confess to being profoundly skeptical about that), then I would want to upgrade the quality of my sonic enjoyment by getting the more expensive one.
Any further light you or other forum members can shed on this question would be highly appreciated.
you barely audible difference in sound quality. In a blind test you you will not hear a difference. I had the opportunity to listen to a V281 with and without the stepped remote control for a week .I decided to keep the one without because in a blind test I could hear a difference and I didn’t need a remote control .If you don’t need a remote control You better spend the extra money in better cabling the v281 .It will give a much greater audible difference.
