Again some words about unbalanced and balanced signal.
In general it can be said that balanced signals are the better signals.
This is because of their nature.
Feeding unbalanced signals from one item to the other means that an electric signal is pushed from the transmitter to the receiver.
But the electrons which are in charge for this task like to go back to the transmitter because they are missing there.
And they do by using the screen of the cable.
That means that there is always traffic on the screen to accomplish equal potentials ( = ground) among all connected items.
And if some of these items are connected to different wall outlets with slightly differing potentials chances are high that his can be heard as hum.
Now imagine the same situation with balanced signals.
There is no need for the electrons to go back to the transmitter through the screen of the cable because they have a dedicated wire ( = out of phase signal) to do so.
And that means that there is no traffic on the screen – the cardinal reason for low(ered) hum !
Of course these effects are maximized for long cables – therefore professionals will exclusively use balanced signal lines, but also for 1-2 feet distances it is useful to drive them balanced.
Keep in mind:
- Only balanced lines will enable proper ground potentials
- Improper ground will generate crosstalk issues and hum
The features of HPA V281 concerning unbalanced and balanced signals:
The internal signal processing of V281 is unbalanced !
This is the only way to feed unbalanced and balanced input signals and generate balanced and unbalanced output signals.
The line-out circuitry and the headphone amps inside V281 are totally independent from each other and driven by a dedicated circuitry. That means that they will not affect each other.
For example you can feed an unbalanced signal and generate an unbalanced line-out signal and a balanced headphone signal simultaneously.
Or you can feed a balanced input signal and generate an unbalanced line-out signal and an unbalanced headphone signal.
Special function:
There are 4 headphone amps inside V281. These are left in-phase, left out-of-phase, right in phase, right out-of-phase.
They are connected to the 4-pin XLR headphone socket.
Further one phone jack socket is connected to the left and right in-phase signals and the other phone jack socket is connected to left and right the out-of-phase signals.
That means that two SE headphones will be driven by their own amps so there is no impedance mismatch.
Fully balanced amps:
These are amps where the internal structure is balanced, meaning they have two internal stereo paths: in-phase and out-of-phase.
They feature 4-way volume control and other 4-channels features.
If such gear is treated with unbalanced input signals only 50 % of the amp is active.
True “fully balanced” equipment is rare as there is no real profit to do so but lots of disadvantages.
Fully balanced D/A converters:
Such is simple as every better D/A converter chip offers balanced outputs.
This is an easy measure by the chip manufacturers to raise S/N ration.
All a designer has to do is to feed the signals coming from the D/A chip through some more or less complex electronics to the balanced outputs.
If the circuitry is a bit more complex (like inside Violectric / Lake People converters
- a volume control is possible
- or different analog outputs levels whilst maintaining low output impedances
- or active unbalanced outputs which are derived from the balanced lines by using differential amps.
Cheers, Fried
