To a certain extent, as the higher gain offerred by the balanced DAC allows you to set the pregain on your amplifier to a lower level, hence possibly avoiding distortion from higher amplifier gain.
But otherwise you get no improvement in the signal path when using balanced in for balanced out?
And the amp will keep using it's 2 boards for the balanced output?
I am asking because I am trying to figure out how I will connect my setup in case I'd buy a V281.
I'd prefer to connect it unbalanced if it doesn't matter.
I also wonder how many wires there are in a balanced headphone cable with dual 3-pin xlr connectors, 4 or 6? If I'd cut a cable like that and connect it to a 4-pin xlr connector, would that work? Or would I need a 1/4 terminated cable to reterminate it to 4-pin xlr?
