zhgutov
- Dec 17, 2014
Are there any optimum settings for the output volume of a DAC or V281 when connecting from the DAC to the balanced or un-balanced signal inputs on a V281?
I could use the volume control on the DAC, but would use the channel balance control on the V281.
My DAC produces maximum Balanced 4.6 Vrms @ 0dB Volume – Impedance 78 ohm and Un-balanced 2.3 Vrms @ 0dB Volume – Impedance 39 ohm.
I will probably be using DAC and V281 with HD800 S headphones.
If using a Resonessence Mirus Pro DAC with the V281 could anyone suggest suitable Balanced interconnects between the DAC and V281 (max 1.5m long cable)?
Does the 128-step relay attenuator upgrade provide an increase in sound quality?
Has anyone used the two unbalanced phone jacks as left and right channels Balanced mode by re-setting the internal jumpers?
It is better to use the balanced connection everywhere in your case, because your DAC produces balanced signals, V281 is balanced, and your headphones may be connected to the balanced outputs.
I use 4-pin XLR with the internal jumpers set to BAL. I don't use 6.3 mm outputs for that, but I tried both options (jumper settings) and in my oppinion the BAL setting produces slightly better scene. The difference is small, but I always prefer BAL option setting jumpers back and forth. But I think you can make this experiment by yourself and make your own decision
It would be interesting to me if you can share your impressions on that.
