Fegefeuer
- Mar 17, 2011
No internal differences.
Based on the previous post I would guess notHi there! Is there any difference between FE and non-FE versions?
The difference between v280 and v280FE lies in the back panel and pre-gain switch.Hi there! Is there any difference between FE and non-FE versions?
If you set the rca as inputs again (from inside the unit as I understand you changed them to output/throughputs) then from what you have written (“rva will have priority) if both rca and xlr inputs have been plugged in then the rca will be the one being used by the unitCan anybody clarify what the manual means when it says when the RCA and XLR inputs are both present, RCA has priority? I have been using the RCA as output buffers, but I'm thinking of running my RME into my V280 and the XLR inputs are already used for my Brooklyn DAC+
Does it mean when you plug cabling into the RCA jacks there is some physical mechanism that turns off the XLR input, or is it that when the amp detects signal on both inputs, it uses RCA (I hope)... thanks
Thanks. This doesn't make sense to me but it's what I thought. So you have to unplug the RCA cables for the XLR connections to be used, even when there is no input on the RCA cables?If you set the rca as inputs again (from inside the unit as I understand you changed them to output/throughputs) then from what you have written (“rva will have priority) if both rca and xlr inputs have been plugged in then the rca will be the one being used by the unit
Actually try that out.Thanks. This doesn't make sense to me but it's what I thought. So you have to unplug the RCA cables for the XLR connections to be used, even when there is no input on the RCA cables?
Well @Fegefeuer knows everything so I expect a clue stick is imminentit won’t hurt the amp - it’s the only way to confirm i guess
Thank you! I was thinking that might be it from my memories of working on (destroying) receivers in the 1970s.It's a physical thing, independant of any signal being played. That's how it is. Plug in the RCA and XLR is quiet.
