- Aug 25, 2013
I would've jumped on the GenV if I hadn't already bought a Basic IIIa recently
Hey guys, do you know if there's an internal switch on the theta dspro gen v units to get the output to go to rca line out from balanced out or are both outputs supposed to be live?
If that's the case then there's no way for me to use this dac as amps I own are all se. Although I do have 2 balanced amps to test with at the moment.
Can anyone confirm going from balanced 3pin xlr line out to se line in via adapter is a no go?
Another question, more general than vintage dac. If using the balanced output, can one adapt it to single ended via 3-pin xlr female to rca female adapter without causing issues to the DAC? The pin out I believe is 2-pin on XLR as center of rca and 1-pin 3-pin both are tied to outer of rca - this is a standard I presume.
Are the voltage/volume output the same between rca and balanced in the theta units?
