castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
well consider, from 0.5V to 1V it's +6db. so I guess you can enjoy this "horribly wrong" value at 1khz without too much worries for most practical uses ^_^.
Haha, I thought it was close enough, but I had to ask.
I'm afraid I still need you to help me take baby steps through this though as I'm not 100% sure of what else needs to be done.
So where I am right now;
1. My DAP is playing a 1khz tone through my IEMs.
2. I have removed the right hand monitor to reveal the 2 pins at the end of the cable
3. I am attaching the two prongs of the multimeter to the 2 pins on the cable and attenuating the volume until the meter reads approx 2v
4. Now what?
0.2v !!! if you're going to use the values from the er4's measurement certificate. it's the only reason we pic this, it's the value Ety used, nothing more.
then you plug the er4, put it into the veritas set up whatever it is you think you need to set up and in REW you use the SPL meter for calibration. calibrate with external signal to use the test tone into the IEM(so that it measure 1khz only) and just enter 104db or 104.5db(whatever your certificate gives for that er4 driver fed 0.2V) and you're done.
now when you measure something, you can read how loud it's going directly on the measured graph.
it makes things way easier for measurements afterward to do them all at about the same loudness, make sure you're not killing your IEMs with 130db or simply to have meaningful values on the graph and calculate the actual sensitivity you're getting compared to specs(like Tyll does).
Okay, I try to make it as easy as possible for you
1. Don't take your DAP. It probably has high-z out. Take the 0.47 Ohm out of your Geekout.
2. Use a Y-splitter
3. Use one output of the Y-splitter for your ER4 and the other one for a cable like this:
4. Connect your multimeter to cable 3. from GND to left or from GND to right (doesn't matter).
5. Play the 1 kHz 0dBFS file in loop.
6. Adjust the volume to 0.2 V aka 200 mV and for god's sake do not feed your IEMs with 2 V!!!
7. Go on with what @castleofargh has written in post #78.
If the output impedance on my DAP is low enough, ie less than 1 ohm, would it be ok to use?
Should be okay then, but I really don't know how you would use a DAP with REW...
I'm probably being a doofus here and missing something obvious, but why would it matter as long as the veritas is connected to the PC and is being recognised by REW?
USB DAC mode??
That's a valid point, but not every DAP can do this.
I wasn't going to use it in USB DAC mode, but if I'm purely using it to test the SPL of my IEMs then why would I need to?
As soon as you need to use REW.
@bartzky
, have you ever used .req files with REW for EQ/correction? These are binary files, so I've having fun editing them Is there an easy way to make up and import parametric EQ files?
