- Feb 19, 2013
krkrkrkr <- sound of me laughing
yes it's done with the veritas, else there is no point. a test tone could be full scale(reaching 0db) or not, as the multimeter will measure the signal, if the signal isn't maxed out you need to account for that when estimating the actual max voltage you get from the amp at a given setting. it's a silly detail, but I've messed up with that a significant number of time so I mention it ^_^.
I'm all for dirt cheap multimeter, I was just warning that those stuff aren't audio analyzers, the AC voltage measurements will most likely be made to work well on 50 or 60hz and 110 or 220volt for home usage. it's not designed to measure 15mv at 20khz. some can be, but they cost real money.
so what I did with my dirt cheap one was to take my fiio X1 look online for the max voltage output and measured several sine waves at different frequencies to check if at least one would give a proper result. then I checked with the tones that seemed to work into other DAPs, cellphones, dac/amps, where I could get the max output voltage to confirm that it wasn't luck. once you know you can trust a method for your multimeter, it's all good.
they most likely measure the efficiency the very way we want to do it with the veritas. they have a calibrated coupler, they send a 1khz tone into it at 0.1 or 0.2V or whatever, and measure the output with the calibrated coupler. even if it's expressed in db, what is measured is the voltage.
yes I said certificate in reference to the paper with measurements that comes with the er4. but really the general specs are fine too. for example it's written on mine that the drive level is 200mV and the IEMs give respectively 104.5 and 104.6db at 1khz.
the specs for the er4sr are 98db for 0.1V. double the voltage is 6db louder, that's how it always is for all analogous audio signal. but if in doubt you can always jump there to avoid having to calculate it yourself http://www.sengpielaudio.com/calculator-gainloss.htm
so 98db with 0.1V means 98+6=104db into 0.2V we're 0.5db wrong and I think we can survive that magnitude of error ^_^.
I'm not sure I get the rest of the questions. if you have a multimeter you can check current whenever you like with any frequency. the accuracy might be given in the specs of the multimeter. but a little very serious advice for those who aren't too familiar with multimeters, the current settings are where you can blow the fuse! it's fairly hard to mess up with voltage and kind of impossible to mess up with resistance. but it's easy to mess up with current measurements, so always care about the setting and check that you're not on current next time you're using the multimeter. I always set it back to voltage and move the probe before turning it off, because I'm paranoid and I don't trust myself
and yes different test tone frequency equal different current frequency and different interaction with the IEM. but I really was talking about using lower frequencies and the multimeter just to make sure we get the right voltage calibration. once we move on to using the veritas, the frequency response isn't properly calibrated so there will be some matter of guessing anyway based on the FR of the IEM. nothing is perfect, and it's even less perfect when like me you go for cheap gear
Hey Castle,
so I have a multimeter now but electronics novice that I am, I'm still not sure where I'm taking the reading from.
If it's not too much to ask, could you point me in the right direction?
Cheers mate
