A month later than I actually intended (transferring money from my bank account to my PayPal account took longer than expected, the package got stuck at customs clearance for two weeks, my microphone input was not powerful enough so I had to buy another interface), I finally get reasonable results from my rig, though it is not 100% calibrated for raw data yet.
By the way, the StarTech interface Luke recommends has got a pretty good microphone input (it can be considered as ruler-flat from 20 to 20000 Hz) that has got lots of power for amplifying the mic signal, but its output is not the very best and has shows some non-linearity in the sub-bass and treble above 10 kHz, so results won't be the most accurate when using the built-in output (unless you take it into account when you build the FR compensation curve).
By the way, does anybody know whether it is somehow possible to apply two FR compensation curves at the same time in Arta? I have searched and tried, but nothing found nothing yet.
It is just that I have built a compensation curve for raw measurements that was modeled after the IEC 711 coupler, but have also made a diffuse-field compensated curve based on
Hammershøi's & Møller's averaged eardrum response curves from 2008; and now I don't want to create a third compensation file by hand as it would take some more hours to calculate and add it to the "IEC 711 raw" calibration file.
