Here's a quick description of my test setup for headphone frequency response. Perhaps I can post some pictures later if anyone is interested. I have a 4X5" block of fairly stiff foam about 2.5" thick, and the headphone ear piece sits flat against the large surface, creating a seal. Inside the area centered around the headphone ear piece is a funnel shaped hole, 2" in diameter at the outside and around 3/4" at the inside, about 1.5" deep total. This hole is larger than an ear cavity, but I thought it was better to have it too large rather than too small. No attempt was made to make it look like an ear cavity, it's just a round, funnel shaped hole. A Radio Shack SPL meter's mic is inserted from the other side of the foam, with the mic element flush with the bottom of the hole. The foam provides a good seal around the mic. The headphone is fed 1/3 octave sine wave tones from a Neutrik signal generator through an amp with flat frequency response. The amp I used this time was the Sudgen Headmaster. The level was calibrated at 1 kHz at 80 dB SPL, C weighting, on the RS meter.
One thing I didn't take into account when I posted some data late last night was the C weighting deviation from flat response. C weighting is down 3 dB at 31.5 Hz and 8 KHz. When I publish the curves I can factor in the error caused by the C weighting. The RS meter only has either C or A weighting, there is no option for no weighting factors. The A weighting is even more drastic.
With the C weighting errors corrected, I measure the W2002, realitive to 1 kHz, + 2dB from 100 to 65 Hz, flat at 50 Hz, -4 at 40, -7 at 31.5 and -8.5 at 25. I would say this is excellent performance. Good subwoofers can do the really low stuff better, but in turn suffer from erratic response due to room interactions.
I've been guilty of comparing bass performance of various headphones to the Sony V6, which reproduces 31.5 Hz much stronger than anything I've heard. Now, let the truth be told, the Sony V6 is a CHEATER!
The V6, after correction, is up 2dB at 20 Hz, which is pretty amazing, but it's also up around 10 dB from 125 Hz to 40 Hz. I've always felt that V6 was heavy in the bass area to a fault, but admit that on certain material it can be seductive.
