Neithan
I don't know who fault it is, but there is not one single person that tried it and didn't like it!
I just want to plug my IEMs on mine
then hurry up and get back to work... lolI don't know who fault it is, but there is not one single person that tried it and didn't like it!
I will try it with the Prime DAC, or with my Fiio M11s as DAC.@Neithan
...and here it is with your favorite iems... with the help of the Shanling UA4 it is truly a magical sound... details, naturalness, power, tonality... a truly remarkable mix.
Ahhh... I forgot you got the full package. They say the Prime dac is exceptional... it will be a good challenge for the FiiO... Then tell me what you think... in case I'll give it some thought too.I will try it with the Prime DAC, or with my Fiio M11s as DAC.
I have high hopes for the Prime DAC
Yeah I went all in.Ahhh... I forgot you got the full package. They say the Prime dac is exceptional... it will be a good challenge for the FiiO... Then tell me what you think... in case I'll give it some thought too.
I will listen to mine next weekPulWtop - Lotoo PAW S2 (line out) - RA2BFE - PULA PA02
You have no idea what this synergy is... just one word to describe it: Music
I have the EF400 and the RA2BFE but not the Prime DAC, but from what I understand from Andy's review on Youtube (Donglemadness) the Prime Dac should have the classic delta/sigma sound, therefore less musical and analog than the R2R present in the EF400, but more revealing and analytical. I think they are two complementary DACs.Hi.. has anyone compare the Ra2bfe combo prime dac stack to hifiman ef400 ?? Or maybe can give an insight between those two?
Thanks
Ok.. So its a different kind of sound sig. Im about to use it with maestro se iem . Its a basshead iem, if i pair it with ef400 . Might go too warm for it i guess?I have the EF400 and the RA2BFE but not the Prime DAC, but from what I understand from Andy's review on Youtube (Donglemadness) the Prime Dac should
With the EF400 I easily listen to the HER10D which are headphones with a high bass weight, but also very extended in the highs so everything is balanced and they don't bother me at all. Of course, pairing an EF400 with an iem/headphone that has a lot of bass and little treble is not exactly the best... any R2R prefers balanced iem/headphones, but only listening can tell you what the situation really is. The Prime DAC, on the other hand, being more balanced and revealing, could certainly be the right choice for particularly generous bass IEMs/headphones.Ok.. So its a different kind of sound sig. Im about to use it with maestro se iem . Its a basshead iem, if i pair it with ef400 . Might go too warm for it i guess?
