VE Odyssey - Discussions and Impressions Thread
Nov 29, 2019 at 2:37 AM Post #226 of 244
how easy hard is it to make odyssey hd play 32bit audio?
am thinking of buying it
can anyone tell me what is the full range of audio output the odyssey hd can play?
on the site it only says :24Bit/96kHz 32bit/384khz
can it play 24bit/192khz?
Oct 14, 2020 at 1:02 AM Post #228 of 244
you can choose from 24 192 & 32 384 fw when you buy them
Cheers
Lee
p.s. just saw this thread got updated from the facebook group~
May 16, 2021 at 1:02 PM Post #229 of 244
For those using Odyssey HD on your Android phones, are you guys facing the issue where the volume suddenly gets low when you are switching apps and play some media on other apps? Also, when I'm using my Music app, I get 100 steps volume whereas if I switch apps it follows the usual 16 steps and when I return to the music player it retains 16 step volume as opposed to 100 steps when I connect the dongle and straight away launch the music app.
Is the dongle or some fault of my music app? Any help is appreciated. TIA.
May 17, 2021 at 2:37 AM Post #230 of 244
this is a bit random but out of all my USB-c dongles only ve odyssey (non-hd) and energiser brand works on my new ps4 slim with usb adapter as headphone/headset output
not even my apple usb-c dongle won't work on ps4
May 31, 2021 at 12:00 AM Post #232 of 244
My DQSM Hermit 6.8mm single DD only works (best) with my VE Odyssey HD. :*(
it is decent for pretty much all single DD (iem , can , earbud )
but it won't go as far as being the best if you count all those 200+ dongles lol
Cheers
Lee
May 31, 2021 at 4:51 AM Post #233 of 244
@zhibli06 is there any way to upgrade/downgrade firmware updates? I searched but couldn't find anything. Would appreciate your help.
May 31, 2021 at 6:33 AM Post #234 of 244
Jun 1, 2021 at 8:15 PM Post #235 of 244
Aug 23, 2021 at 9:49 PM Post #237 of 244
I just order monk plus spc cable...
Until now it only matches with JVC FX1100 sensitive iems...No much yet for earbuds..
Do you want to say the sound quality of MP SPC is similar to or at the level of FX100? As far as I know, FX90 and FX100 are very very good earphones with detailed warm sound and huge Sub-bass. Is SPC like that?
Sep 10, 2021 at 2:10 AM Post #239 of 244
Careful of using this in your smartphone. I usually sleep with these and VE Monks on and I got waken up by stranger voices. Turns out that these automatically answers calls so it answered a random call from a stranger while I was sleeping. Not sure if it's just my unit but that's pretty terrible. I made to sure that it's not just my phone since I tested different dongles and family member's phones. VE Odyssey consistently automatically picked up calls.
Sep 10, 2021 at 3:17 AM Post #240 of 244
Not only this, it also automatically plays music even if you close the app and kill it from recents menu. For all it's pros, it is indeed very difficult to keep them plugged in on standby.
