emorrison33
I purchased this tube from Tube Depot. Philips PCC88. Doesn't a white top mean that the tube was compromised/leaked?
I contacted Tube Depot, and they said it's bad. They are sending me a replacement. What would happen if I had stuck this into my Vali 2?I purchased this tube from Tube Depot. Philips PCC88. Doesn't a white top mean that the tube was compromised/leaked?
It might have blasted off and launched 5 feet into the air before exploding and showering the immediate area with glass shrapnel!I contacted Tube Depot, and they said it's bad. They are sending me a replacement. What would happen if I had stuck this into my Vali 2?
At least they're sending you a replacement, that's good then.I contacted Tube Depot, and they said it's bad. They are sending me a replacement. What would happen if I had stuck this into my Vali 2?
LOL jokes aside would it cause any serious issue? Or just bad sound but otherwise ok?It might have blasted off and launched 5 feet into the air before exploding and showering the immediate area with glass shrapnel!
It looks as though the vacuum was breached; there is no reflective material inside the tube top. I doubt that the tube would function. If it were in the Vali 2, my guess is that any circuit protection would be tripped.At least they're sending you a replacement, that's good then.
Oh please. Talk about exaggerating. It could, however, have formed a singularity and quickly developed a black hole consuming most of the Milky Way galaxy. Disaster avoided, thankfully.It might have blasted off and launched 5 feet into the air before exploding and showering the immediate area with glass shrapnel!
It would probably not sound at all. The loss of vacuum would cause the filaments to fry instantly (like losing vacuum in a light bulb). No filaments = no heat to the cathodes = no electron emission.At least they're sending you a replacement, that's good then.
LOL! If you turn the volume knob up and hear sound in the headphones, it's likely on. Hope this helps.Got my 7n7 adapter (less than 2 weeks from Bulgaria, quicker than it took to get the tube from the US - go figure) and can finally try out the much coveted "Frankie". So far the only bad thing I can say is that since I unceremoniously de-LEDed my Vali2, and the "Frankie" has so much getter flashing, I can't tell if the amp is turned on or not.
I'm currently on page 364 of this thread, starting from the beginning. I just purchased an a 6922 to 6SN7 adapter from @Deyan and am looking for my first 6SN7 tube. Vivatubes has the new production Psvane tubes (CV-181T MKII, 6SN7-SE tennis ball & 6SN7-UK) and I like the looks, but how do they sound? My favorite tube so far has been the Philips PCC88 (mentioned a few posts back). I have mostly Grado HP's so I like to tame the highs a little, rather than using the Loki. Trying to keep it under $100 for my first 6SN7 tube. I saw this tube as well: https://www.vivatubes.com/tests-nos-sylvania-usa-6sn7wgta-black-t-plate-top-o-get-brown-base-tube/
What do you "experts" think?
