Mr Trev
That covered it. What measurements mean are one thing I've never really bothered looking into - I'm getting too old to do new book learning, it'll end up pushing out the stuff I've already learnt.It really depends on the seller. Some state that a 20% spread is a "great match" and I don't agree with that at all. I think more of a general but unwritten industry convention is that 10% or less difference is a good match. I try for 5% with the tubes I use. But a lot depends on how high they test. If both sections are within 20% of NOS, any imbalance will likely be inaudible (for instance, one section tests at 10% higher than bogey/NOS and the other tests at 10% below bogey/NOS). In your example, if 2200 is bogey, then the other section is still above minimum (with minimum usually being around 60% of NOS), so an imbalance probably won't be audible....probably. Depends on the tube and the amp it's used in as well. Power tubes like 6550's, KT-88's, EL-34's, etc are going to be less forgiving with big GM or emission differences. Small octals and novals not so much...usually. But 1600/2200 is a 22% difference. Not a tube I'd go after personally with that big a difference, but that's just me.
Don't know if this explanation helps at all or just confuses things worse (which is one of my specialties ).
So, how do test values effect the sq?
Back when I first bought a tube amp and was wondering why anybody would even look at ads where the tubes have lousy test values. Then I started thinking… well, what if I went out and bought a whole bunch of "bad" tubes for dirt cheap. Then listen to 'em and see what I like so I'd know what "good" tubes to start looking for. The sticking point was I have no idea how bad a measurement can get before the sound falls off a cliff.
