bcowen
Finished the modification to the cover of my b-stock Vali tonight. No socket saver needed here!
Beautiful! Very nice. Now all you need is a 6J5 or 7A4 adapter.
Oh boy, more adapter madness! So far I'm happy with the sound of the new Tung-Sol tube.
Holy carp. You are the reamer-master (uh, that's a sleazy double meaning). Its edges are nice and clean. The air vents didn't warp. Dremel-master. You're that. Nice, eh.Finished the modification to the cover of my b-stock Vali tonight. No socket saver needed here!
Looks good from here. . As popular as the 6sn7 rolling appears to be, Schiit should make these modified covers available. But of course, make them look like the stock one, only with the bigger hole.Thanks everyone, it was a lot of work with a Dremel with drill press accessory. I'm sure there are faster ways to do it. I used a circle template to draw a 1.5 inch diameter circle on the underside of the cover, then drilled a series of small connecting holes to remove most of the waste. Finished with the sanding drum and slowly worked to the line. It's not perfect, but I'm pleased with the result.
I'd like that option.Looks good from here. . As popular as the 6sn7 rolling appears to be, Schiit should make these modified covers available. But of course, make them look like the stock one, only with the bigger hole.
Mind you, @Jason Stoddard commented on an older posting about having to be very careful about air vent placement, the number and diameter of holes (and I'm assuming offering chassis modifications). I can't find the exact post, but it was about how air vents are governed by either CSA-, UL-, CE-, EU- , or USA- electrical safety certification. Some ding dong will find a way to slip their fingertips in the larger gap and grope the main board (unlike my Valhalla, I gather the voltages on the Vali are ~60V).
Ah well. If I wanted that feature, I'd have to pick up a Lyr-3 without any extra expansion card (I suspect the sticker covering the expansion port actually has a metal plate under it... or the sticker's tamper-resistant... to prevent ding dongs [see above] from groping the main board).
bochawa...... Your brother?Beautiful! Very nice. Now all you need is a 6J5 or 7A4 adapter.
All good points. Never considered those.I'd like that option.
