bcowen
One last thing, I have many pairs of hemostats but the ones I use for this application do not have a huge amount of grip strength, I would not run the risk of flattening out the inside portion of a tube pin so be careful if you buy brand new ones and keep the pin toward the end where there is less force applied.
I've been using a pure copper alligator clip which seems to work OK. Was just wondering if you were using something fancier or jealousy-inducing. We use something a little more robust at work on the stainless panel welder -- 42 lb copper billet plates.
