OHPC
- Nov 28, 2006
Did you insert it all the way inside your ear canal? Actually, this is the first earphone I have used that goes deep inside my ear canal, so this is the reason I am saying it won't fall off. I almost feel it is touching my brain, if you know what I mean.
If I just let it rest inside my ear without deep insertion, it is a different story, of course. I found that most of my use won't be with they inserted deep my ear canal, since I will be using my pair at home/work and I will have no use for them to be tightly inserted. I might even try using the medium tips for this purpose. They felt uncomfortable the first time I tried, but I will try again and see how they fit. For my ears, big tips are out of question, they hurt.
BTW: are we supposed to use the Vibes really deep inside the canal, or just inserted a little? How are you using them? I am curious. I have seen some pics, some people insert them all the way, others let they almost hanging out of the ear canal.
Originally Posted by Yen /img/forum/go_quote.gif I had the opposite feelings than OHPC that I think my pair with biggest tips is rather loose. They wont fall if I turn my head, but quite easily anyhow. I had a pair of Shure E2gs and I used M-sized tips. I wish these Vibe's tips are a bit thicker and sturdier, so that they would fit more tightly. Well, it is a compromise because we all have different ear canals... |
