HifiPenguin
- Dec 9, 2012
Depends what you listen to. The mids are quite recessed, which means that many genres will not sound great on them. I listen to everything so that sucks a bit for me, but I mostly listen to rap and electronic genres and they are AMAZING for those genres. The soundstage is WoW, amplified with my Rocoo P, sounds incredible.
I also owned M50s for over two years, just sold them actually. They are more balanced and will sound great with almost everything, if not everything. SO it depends. If you listen to what I listen, ten I definitely recommend spending that extra money for the m100s, but if you listen to other types of music, then get the m50s.
I absolutely love how my m100s sound witht he paper towel mod. I also have the LP pads and they drastically change the sound. The mids are brought out more than any paper towel mod and the bass is brought down a lot!! I was actually able to enjoy some classic rock. Not the best, but much better mids than the stock pads.
I also believe that the paper towel mod (top & bottom) sounds better than anything on the m100s.... better than stock earpads (unmodded) or even the Lp pads. The bass is just so perfect.
How does the M100 fare against M50 ?
