daphen
- Mar 11, 2012
But isnt The cables terribly short?
Just food for thought...I found the E11 way to big to take around portably, I did have a iMod 5.5g though so it was a tick setup, I much prefered the Z02 when I had it as for starters its much thinner than the E11 and as it has 30 bass contours you can precisely set the bass boost where with the E11 I found the 1st setting wasnt enough but the 2nd was too much...also I found the Z02 to add a bit of musicality to the music where the E11 was completely neutral...
If you need any more help feel free to PM me as I dont want to clog up this thread
My god - just listened to this with my M-100's. That bass, so good.
emonloid4 - "Dolls" - emon(Tes.) feat. Megurine Luka
(Intro is a bit repetitive, but this really shows what the bass can do.)
I'm considering to purchase these headphones when they become available. I know some of you already have them and tested them out. Can you please let me know how good they are.. I have never owned a decent headphones before. Here's what I want in the headphones:
*sound quality (good bass)
*sound isolation
*portable(no amp required)
*operates without batteries
Thanks,
You need to shop around more. Try Amazon.com
This one seems the best based on reviews, but its short:
http://www.amazon.com/Woodees-VOIPAD35-Laptop-Adaptor/dp/B0046RE60I/ref=sr_1_1?ie=UTF8&qid=1350581938&sr=8-1&keywords=laptop+voip+adapter
This one seems to be the longest, if you need flexibility, and it's dirt cheap:
http://www.amazon.com/2-5mm-Mobile-Headset-To-Converter/dp/B000IZCUTQ/ref=sr_1_3?ie=UTF8&qid=1350581938&sr=8-3&keywords=laptop+voip+adapter
Make sure you read the technical specs first to be sure either one would match your needs The second one is longest, but it says 2.5 MM adapter. I'm not sure what the standard pc plug in size is, but I've seen 3.5MM ones too. Shop around. I'm positive you'll find a solution to your amp&mic combo problem.
There is a great deal of detailed information here regarding the sound. Long story short, the M-100 will check all your boxes plus some you didn't think of. The only bad thing about the M-100 being your first headphone is that they will spoil you compared to everything else.
I've heard the the noise isolation is on par with the M80's... Is this true? Because I am on an airplane at least twice weekly (usually more) and the M80's do not isolate enough sound for me to be completely satisfied... I want to buy the 100's but I need to know with absolutely certainty that the isolation is better.
