Miss Roxy
- Feb 20, 2014
Mk. Thanks guys.
[COLOR=0066FF]I've went ahead and purchased C5D...[/COLOR]
[COLOR=0066FF]AND IM OFFICIALLY BROKE! XD[/COLOR]
^ Haha.
By the way, what do you recommend for portable music player? Probably gonna get that after I receive my next paycheck.
^ Haha.
I'm very happy with my DX50, but it has some quirks that rub some people wrong, so do some research on it if you decide to go this route. I liked it more than the X3, thus why I have the Dx50 and not the X3. Its a no frills music player, but as you will read, sounds great. $250.
Also, unless you have tiny ears, order the XL pads. the stock pads are a joke, and the only thing I (greatly) dislike about the M100's
Stupid question, and this might not be the best place for it since it doesn't directly concern the m-100, but since we've been discussing amps and dacs that pair well with the m-100 I figure I'll ask it here. Right now I'm using the line out from my ipod classic to my fiio E12 (to my m-100). If I were to instead use the line out of the ipod classic to the C5D's usb input, would I be "double daccing" since the ipod classic already has a dac in it? And if so, would this negatively effect the sound?
Hm gotta wait til' my M100 is here to see if I need XL pads. Is it easy to do? ( to swap the stock pads with XL )
A little more difficult than some other headphones, but they are swappable with a bit of force. They snap in. There are some videos on youtube to help with the process like this one from our buddy miceblue: http://www.youtube.com/watch?v=tgat9VVVLlc
Actually, let me play devil's advocate to myself. They look a lot nicer than the stock pads, so that actually does make a difference to me, LOL.
I haven't chained headphones together but I do use the splitter cable on my Mac at work with the fork going to some self-powered speakers.
Splitting a signal doesn't degrade or decrease the signal. What it does do is increase the impedance on the line. All that means is you need a little more power on the source side to offset the increased load. In other words, a little more volume.
With a caveat: dirt and corrosion on the contact points (plugs and jacks) can degrade the signal. Pretty much everyone making audio connectors and cables uses non-corroding plating of some sort so corrosion shouldn't be an issue. Dirty or oily contacts can be a problem so clean the plugs if they're dirty.
It's not a good idea to mix and match different devices without having independent volume attenuation. Setting the master volume loud enough to drive 600 ohm Beyerdynamics without an attenuator on the M-100's will probably blow out the M-100 drivers and maybe rupture your eardrums for good measure.
I'm not sure what you mean by this. Do you mean line out via 3.5mm to usb?
Or do you mean ipod pinout to usb?
This is what I mean by the pinout. https://www.youtube.com/watch?v=psnZmoNznpU
