Magick Man
Daddy Warbucks
- Jan 4, 2012
HiFiMan EF2A, it's a nice little tube amp/DAC combo for $170. I hear the Bravo Ocean hybrid amp is very good for $130ish bucks, but it has no integrated DAC.
The O2 has a very good reputation, but it does not have a built in DAC.
Asuming you do not have a proper DAC, it is better to get a decent combo.
I do wonder though, does the EF2A have enough power to properly drive the AKG's?
Because the K701 does need quite a bit of power.
The HiFiMan EF2A looks like a great deal! Would you recommend it over the Objective 2?
Thanks!!!!
Can someone explain this to me..
OW IMPEDANCE: A low impedance headphone often will be louder out of a portable device. However, in many cases, it is still highly recommended to pair a low impedance headphone with a headphone amplifier. The reason for this is that typically a low impedance headphone will sound far better when fed more electrical current. A low impedance headphone’s frequency response can be dramatically altered and improved (especially in the bass region) when paired with a headphone amplifier offering sufficient current. In some rare cases, there are low impedance headphones such as the AKG Q701 which require high current not only to sound their best, but to reach satisfactory volume levels as well. This is an example of an instance where the headphone’s impedance rating is not very high, but its sensitivity is not very high either. This means that more power is required to drive the headphones.
Thanks in advance.
I'm sure this has been discussed a dozen times but just in case someone has an opinion - please suggest an amp under $150 that will help widen the soundstage and warm up the headphones. I listen to mostly rock and jazz. I primarily bought these for listening to jazz trios and quartets - piano, upright bass, drums.
btw if anyone can recommend some piano led jazz with lots of walking bass lines I'd appreciate it.
What is there to explain? Higher impedance means higher voltages to generate the same current, and in many cases amplifiers are what supply these higher voltages (higher than portable setups, at least).
My two cents worth: assuming you have two cans with the same sensitivity, i.e. need the same amount of power to generate the same SPL, but the two cans have different impedances, then the lower impedance can will need a bit more current, a bit less voltage. The higher impedance can will need a bit more voltage, a bit less current.
However, when paired with low impedance cans that need a lot of current, they might become unstable and supply insufficient current.
My two cents worth: if the cans need more current than the amp can supply, the amp will then current limit, i.e. music will be clipped (distorted). Instability is something a bit different.
For obvious reasons portable sources tend to fail both in supplying a lot of current or voltage.
If a source is at its limit in supplying current, distortion goes up dramatically. But more importantly, distortion goes up more in some frequencies than it does in others. Additionally, in many cases the amplifier can't supply enough current in one frequency, but it can in another. This is why bass response might fall in volume and become distorted with some combinations of amplifiers and headphones.
I assume you mean "can't supply enough current in one frequency band". Basically I agree, but this would be dependent on the characterisitcs of the amp, the headphones, the type of music, the recording, you have an excellent point, but kinda hard to pin this down to just the amp or 'phones. Like I said, basically I agree.
Cans such as the AKG K701, but especially the Hifiman HE-6, need a lot of current while not being of very high impedance. This makes it very hard to drive for many amplifiers, and as a result getting the right amplifier is very important.
I own AKG Q701s, you can plug them into an iPad, they sound just fine. They even sound "OK" when plugged into an iPod, just don't expect too much sound quality or volume. But if you want them to really show you what they can do, use a better headphone amp. K701 & Q701 guys love the Matrix M Stage.
What I just said is based on what I've read from other people. I have no credible source to back this up, therefore I would like someone to either confirm or correct what I just said.
Just gonna throw this out there; sure it will get ignored: you will not fundamentally change any headphone with the amplifier. Amplifiers are not tone control devices. And finally, amplifiers will not "widen the soundstage" - that's part of the headphone's design (and there's not a lot out there that gets "bigger" than the 70x). They're gonna sound like 70x's forever.
The 70x don't require anywhere near the same power inputs as many planars; 1-2 mW is not earth-shattering in most cases (that's mW, not W). The output impedance "thing" is unlikely to produce a "wonky" (i.e. non-uniform) FR variation with the 70x (contrasted to something like the HD 650 or T1), simply because their impedance FR is fairly flat. If a given amplifier can provide suitable output power, it can drive them; and the output power available from an amplifier does not correlate to it's output impedance (nor does its price - there are many inexpensive amplifiers/devices with low output impedance and low output power, and many expensive devices with relatively "high" output impedance). The receiver is probably suitable, but without any information about it, it may not be. There's plenty of good options in your $100-$200 range, like the HiFiMan, the Fiio E9, the O2, and probably more used devices than you can shake a stick at.
Well said.
But the impedance of the K701 does go up with frequency. If you would have an amp with an output impedance of about 60-70 ohms, then there could be quite dramatic effects on the frequency response.
Additionally there is the fact that lower impedance does increase the dampening factor. Although I don't know how much of an issue it is with headphones if you have a low dampening factor.
Impedance - frequency graph of the AKG K701
And I hope I didn't give any offence, there was none intended.
I find myself to be generally agreeing to what you just said, except for that I was convinced that output impedance and dampening factor did have an audible effect on the sound.
I'm aware that the damping factor is very much marketing hype, but I believe I have read an article or two that showed the importance of a good dampening factor. I'll try and see if I can find them.
I wish more people on this forum shared a more objective view towards this subject. It could help so many newbies avoid unnecessary spending.
Oh, and rather than saying 'it's simply not for them' when you are not wowed when listening to a hi-fi can for the first time, I think the best advice is to let someone listen to them for some time. I was personally very disappointed when I first got my HD 650's, since I simply expected a lot more performance for 550 euros (I paired it with a Little Dot MKIV). However as time went by you learn to recognize the difference, and when I now listen to even my HD 25 I can still say with great confidence that the HD 650's are worth the money I spent on them. I takes time to appreciate a headphone.
