rosgr63
Can I use the the M2Tech hiFace with iTunes on a MacBook Pro running Snow Leopard, or I would have to wait for the Mac drivers?
Originally Posted by rosgr63 /img/forum/go_quote.gif Can I use the the M2Tech hiFace with iTunes on a MacBook Pro running Snow Leopard, or I would have to wait for the Mac drivers? |
Originally Posted by jkeny /img/forum/go_quote.gif this link shows the Musiland jitter but I wouldn't take it as gospel. DIYHiFi.org • View topic - Musiland 24/192 USB Asynchronous Devices this shows a graph of the Musiland Vs AP SYS2722 Digital Generator |
Originally Posted by jkeny /img/forum/go_quote.gif this link shows the Musiland jitterbut I wouldn't take it as gospel. DIYHiFi.org • View topic - Musiland 24/192 USB Asynchronous Devices this shows a graph of the Musiland Vs AP SYS2722 Digital Generator The Stereophile jitter measures are useful as they give a relative measure of units so they can be ordered from lowest to highest jitter but I still wouldn't take the figures as gospel. |
Originally Posted by jkeny /img/forum/go_quote.gif BTW, I just noticed that in the Sterophile link given earlier they use a SYS2722 to measure the jitter of various DACs - in the above graph I linked to, shows the Musiland jitter noise against the SYS2722. You can work out what this says ![]() |
Originally Posted by slim.a /img/forum/go_quote.gif Jkeny, I haven't registred yet at the DIYHiFi forum so I cannot see the picture of the measurement you are talking about. However, it seems that according to the discussion, the digital noise floor of the Musiland is 20db higher than that of the AudioPrecision system. Does it mean that the Musiland has 100x times the jitter of the SYS2722 ? (I am basing my guess on the fact that in power measurment 20db is equal to 100x more power) Does the picture give ps/ns jitter measurements like those given by stereophile ? If it is the case, it might give us an idea on how the musiland compares to the Bel Canto and Emu 0404 usb that were measured by sterephile. But I am still skeptical to draw definitve conclusions from those measurements since they weren't performed with the same equipment (digital cables, ...) and the same test protocol. Too bad the stereophile test covered only 3 usb to spdif converters and didn't include a reference pci soundcard such as the lynxtwo to give us a base reference. |
I have to correct my previous measurement result, because I wasn't comparing apple to apple - the 20dB difference in jitter spectrum levels between the AP and the 01USD was not under the same sampling frequency. The 01USD was running at 192k but the AP was at 48k. So the 01USD's performance under the same sampling rate is better than I thought. |
Originally Posted by jkeny /img/forum/go_quote.gif Simmconn, the guy that did the measurements corrected this 20dB figure earlier in the thread: The graph shows a possible 2-5dB higher noise on the Musiland. The question is what is the jitter figure of the SYS2722? FMAK on Audioasylum did some measurements on the Musiland & it was he that suggested a value of <100ps AFAIR (I'll look for the link) |
Originally Posted by rosgr63 /img/forum/go_quote.gif tosehee, if you fed your DAC from the Mac's HP output using an optical 3.5mm/Toshlink cable would you be bypassing the soundcard's D/A converter? What would the SQ be compared to a USB/M2Tech HiFace signal fed to your DAC? |
Originally Posted by regal /img/forum/go_quote.gif When will folks realize that Jitter measurements are 90% hokus pokus and 10% science, an instrument that can acurately measure timings near the speed of light is not available to any magazine with $500k in annual sales. |
Originally Posted by tosehee /img/forum/go_quote.gif That's probably true. I have no clue myself on how they measure and come up with these jitter measurements. You can be the best judge of these products. Maybe it's a waste, and if you feel that way, you can always sell it back at a small loss. |
Originally Posted by slim.a /img/forum/go_quote.gif Jkeny, the only 100ps figure I have read about the Musiland was a theoretical figure guessed from the specs of the Xilinx FPGA used in the Musiland. That guess doesn't take into account the actual jitter at the spdif output which would have accounted for the layout of the PCB, the quality of the clocks and PLLs, the transformers ... You claimed the same thing about the 100ps figure on the Computer Audio Asylum without providing your source. |
Also, while I haven't seen the graph, the comments made by the person who measured the Musiland talk about 20db of additional noise. Then he says that since the Musiland was measured at 192k, the jitter at 48k might be lower. But I don't read anywhere where he talks about 2-5 db. Do you ? |
As for the SYS2722 used by stereophile, the lowest digital jitter they could get was 1.75ns (1750ps) with a Boulder 1021 disc player that costs $24,000. Do you really believe that the Musiland measures 17 times better than one of the best measuring CD players that exist ? Also, I have yet to find a jitter digital measuring device that can go below 0.5ns (500ps). |
Could you please give a link to your sources ? It would be greatly appeciated. Also, could you please copy the graph and post it in this thread so that the readers could see by themselves ? |
