regal
- May 27, 2006
What about the TerraLinkX, any pops crackles or skips ?
Originally Posted by tosehee /img/forum/go_quote.gif I hear this pop every time I select a song to play. If the next song plays automatically, I do not get this issue. I am using Foobar 0.9.6.9 with Windows 7 64b |
Originally Posted by regal /img/forum/go_quote.gif What about the TerraLinkX, any pops crackles or skips ? |
Originally Posted by xdanny /img/forum/go_quote.gif tosehee, Are the pops really loud or subtle?? I am trying to stay away from them as there was a scary issue with my receiver popping: almost to the point where I could get speaker damage. Anybody else with hiFace has this issue? EDIT: Nevermind, I got the answer... ![]() |
Originally Posted by jkeny /img/forum/go_quote.gif Yipee, another sale for the company ![]() ![]() Do let us know what you think, good or bad! |
1, unplug your Monitor 01 US/USD/02US/MINI from your computer. 2, uninstall the old driver. 3, download and install the new driver: http://www.musiland.com.cn/downloads...on_1.0.5.0.zip 4, reboot, plug Monitor 01 US/USD/02US/MINI in, if the control panel shows 'Warning: License invalid', it needs the firmware upgrade, otherwise you can skip the following steps and enjoy it now. 5, download the Monitor 01 US/USD/02US/MINI firmware upgrade program and extract it to a folder('MlCyMonAct' from now on): http://www.musiland.com.cn/downloads...MlCyMonAct.zip 6, run 'MlCyMonUser.exe' in 'MlCyMonAct', it will create a file named 'License.dat'. 7, send the 'License.data' to activate@musiland.com.cn as an attachment, also your product name and serial, double check your mail before sending, the three entry must present and match each other. 8, we will reply your mail in business time using activate@musiland.com.cn, it will include a 'License.key' file as an attachment, save it to the 'MlCyMonAct' folder. 9, run 'MlCyMonProg.exe' in 'MlCyMonAct', it will upgrade the firmware for you. 10, reboot and have fun |
Originally Posted by jkeny /img/forum/go_quote.gif The company have asked me to enquire: What's your driver version- download 1.0.5.0 from here & follow these steps to use it: If you want a more immediate driver update without registering then download version 1.0.3.2 & just use it - the download link is in here somewhere! |
BTW, I would have expected it to sound better than WD HDTV ![]() |
Originally Posted by jkeny /img/forum/go_quote.gif I won't get into bits is bits discussion - you've already stated your opinion - just try the new driver & give an honest opinion as I know you will ![]() |
Originally Posted by slim.a /img/forum/go_quote.gif I did my comparisons of the Teralink-x without the use of an external power supply. |
Originally Posted by erin /img/forum/go_quote.gif Hi Slim, thanks for your interesting reviews. I have the Teralink X and love it. Could I implore you try using an external power supply to power the Teralink X and then report your results. I have found a very large improvement in the sound when using an external power supply. I think you will be impressed. I have had best results when using a 12V SLA battery. Thank you and regards. |
Originally Posted by regal /img/forum/go_quote.gif I did an A-B comparison of 1. Quadcore Desktop- PCI EMU 0404 ASIO optical out - AudioGD 19MK3 - SOHA II -HD650's 2. 2ghz Laptop - TerraLinkX USB - Optical out - AudioGD 19MK3 - SOHAII - HD 650 The laptop is noticeably smoother has more detail and better soundstage. I am really dumbfounded that a change in transport would make such a difference. |
Originally Posted by jsplice /img/forum/go_quote.gif This may be related to some type of electrical noise, since the desktop has A/C power coming into it. With a laptop, you either run off the battery, or the A/C is converted to D/C externally. Very interesting findings though. |
