- Apr 11, 2015
Hi, I have the same usb dongle and works fine for me except for a few cuts in the transmission when I move around the house. I think Its a really good option if you are looking for portability. The biggest problem is that if you are using Windows 10 the system will only allow to stream in 16 bits. Apparently its a common problem in Windows 10 and it doesnt seems to get fixed anytime soon, so keep that in mind before you buy it.
Thanks I am transmitting with Mac laptop
Lets see what happens.
I will try to undo the packaging so as I can return it. I may be able to use a diagnostic "Apple developer" tool called Bluetooth Explorer to put the transmission under the microscope.
Using BT Explorer I know my mac is already transmitting AptX (16Bit) now I want that extra 6 bits(!) to have AptX- HD (24 bit)
